How Do You Integrate (x^2+x)/(x^2+x+1) from 0 to 1?
The discussion revolves around the integration of the function (x^2+x)/(x^2+x+1) from 0 to 1. Participants are exploring methods to approach this integral, focusing on the relationship between the numerator and denominator.
  • Participants discuss various methods to simplify the integral, including factoring and rewriting the expression. There are suggestions to consider the similarity between the numerator and denominator, and to explore the derivative of the denominator. Some participants also mention the importance of recognizing the degrees of the numerator and denominator.
The discussion is progressing with participants sharing insights and hints that may lead to a clearer path for solving the integral. There is a recognition of a potential simplification after correcting a typo in the original problem statement, which has shifted the focus of the discussion.
There is a mention of a typo in the original problem, which has implications for the approach being discussed. Participants are also navigating the use of LaTeX for clarity in their mathematical expressions.
462chevelle
integral(0>1) of (x^2+x)/(x^2+x+1)dx
Factor denominator, and set numerator with A,B,C, etc. multiply both sides by the common denominator.
Since the denominator won't factor at all I don't really know where to start, I could rewrite it into 2 fractions or factor the numerator. Both useless though, I can't find an example in my book for this type of problem.
Any hints on the first step?
Thanks.
It's not partial fractions. The numerator and denominator are similar. Can you make use of that?
Almost, as far as I can tell, if I take the denominator to be u I get du/(2x+1)=dx then I can factor a x out of the numerator and i get x(x-1)/(u(2x+1)). Unless I'm missing or forgetting something.
Sorry, I'm bad at latex so I'm posting a picture of my work. I can't remember if that is allowed or not.
How would you make the numerator the same as the denominator? Something very simple.
You could add 2x+1 and that would be the derivative of the denominator. Then I would have to do that to the denominator. I'll see what I can figure out and post my work.
You're missing the obvious thing and going for more complicated things. What is the difference between the top and bottom?
A constant and a sign.
Do you mean 1?
Well, yes the constant would be 1. I just realized I made a typo on the first post, sorry. Its (x^2-x)/(x^2+x+1) the problem is correct in the picture I posted.
That makes the solution a lot easier you'll be glad to know!
Let me do the original one and see if that helps:
##\frac{x^2 + x}{x^2+x+1} = 1 - \frac{1}{x^2+x+1}##
Since numerator and denominator have the same degree, first do the division to get a polynomial plus a fraction with numerator of lower degree than the denominator. Then complete the square in the denominator.
HMM, this seems to make it easy. I would have never thought of that otherwise.
I think I got it, thanks. I would have been beating my head against the wall all day otherwise.
@462chevelle, since we saved you a whole day of beating your head against the wall, maybe you could devote some of that saved time to learning a bit of LaTeX? It's really not very hard. We have a brief summary here: https://www.physicsforums.com/help/latexhelp/
Here are a few of the things you could have used in your problem. Note that I have omitted the # # pairs (without the space) at the beginning and end in my examples below. I did that so that the LaTeX script remains visible.
Exponents:
x^2
e^{x + 1}
Fractions:
\frac{x^2 + x}{x^2 + x + 1}
Integrals:
\int 3x^2 dx
\int_0^3 e^{x + 1} dx
  • · Replies 16 ·
  • · Replies 105 ·
13K
