How Do You Simplify the Expression sec + csc / (1 + tan)?
17 replies · 5K views · last reply
PHK
sec+csc/1+tan
i tried simplifying it and the farthest i got was: 1/cos + 2/sin + cos/sin^2
im not sure that's even right
ok I'm a bit confused on what your problem is ... please make it a lil more clear
the problem is ...
[tex]\sec{x}+\frac{\csc{x}}{1}+\tan{x}[/tex]
why did you write the 1 ... ?
its not that its, sec+csc and all that over 1+tan. sec+csc
.............1+tanignore the the dots the problem i am and talking about is in the the top right
also (sec+csc)/(1+tan)
You should use parentheses to make your questions unambiguous in future. Also, note that sec doesn't mean anything; you mean sec(x). Ok, well you could write everything in terms of sines and cosines first. Just substitute into that expression, then try and tidy up.
(sec+csc)/(1+tan) ... much clearer
hopefully you see why i was confused, if you want help you got to be clear! or we're going to be going back and forth w/o you ever receiving help. lol
.............1+tan
How are each of these trig functions defined? Replace each one by its definition and see what you get when you add the appropriate fractions.
yea sorry for not being clear.
and i already tryed replacing them by the definition. i just end up with 1/cos + 2/sin + cos/sin^2
what did you multiply by?
i multiplied both NUM and DEN by cosx
i don't really see what else can be done.
I don't see how you got 2/sin, but I can tell you that this simplifies a lot.
Just make the replacements first, then add the fractions in the numerator and in the denominator separately. You'll have a compound fraction, where you can then invert the denominator and multiply. You'll see a couple of things that you can then cancel.
[ (1/cos) + ? ] / [ 1 + ? ] = ?
maybe that's wrong then (1/cos + 2/sin + cos/sin^2), also i tried multiplying by cosx and i get 1/sin + cos - 1/cos i tried going further but it seems like I am doing something wrong. does anyone have the solution yet?
[tex]\frac{\sec + \csc}{1+\tan}=\frac{\frac{1}{\cos} + \frac{1}{\sin}}{1+\frac{\sin}{\cos}}=\frac{\frac{\sin + \cos}{\cos \sin}}{\frac{\cos+\sin}{\cos}=\frac{1}{\sin}=\csc[/tex]
The next step should be
[ (1/cos) + (1/sin) ] / [ 1 + (sin/cos) ] . Add the fractions in the numerator and in the denominator, then simplify the compound fraction you get.
The answer is csc x .
[ (1/cos) + (1/sin) ] / [ 1 + (sin/cos) ] that's the original problem. how did you get csc from that?
Having looked at your source code, I think I should say that you should resist the temptation to provide the full solution to a problem. This forum is intended to guide students, rather than simply hand them the answers...
What does you get when you add (1/cos) + (1/sin) ? How about 1 + (sin/cos) ?
oh i get it thanks i was adding the top part properly but not hte bottm part. thanks
