How does a discharge UV lamp works
The discussion revolves around the operational principles of discharge UV lamps, focusing on how the gas within the lamp is excited to produce ultraviolet light. Participants explore the mechanisms of electron generation and excitation of gas atoms, as well as the differences between hot and cold cathode lamps.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant expresses difficulty in finding a straightforward explanation of how the gas is excited in a discharge UV lamp, questioning the presence of free electrons in the system.
  • Another participant asserts that free electrons exist and are accelerated by the electric field, leading to inelastic collisions that excite gas atoms, resulting in UV photon emission.
  • A third participant mentions that atoms can also be excited through inter-atom collisions.
  • Further clarification is provided regarding the generation of free electrons, distinguishing between hot and cold cathode lamps, with hot cathodes using thermionic emission and cold cathodes requiring a higher initial voltage to ionize the gas.
  • Discussion includes the concept of breakdown voltage and its role in making atmospheric gas conductive.
Participants do not reach a consensus on the initial presence of free electrons in the system, with some asserting their existence while others question it. The discussion remains unresolved regarding the specifics of electron generation and excitation mechanisms.
Participants reference different types of gas discharge lamps (hot vs. cold cathode) and the conditions under which gas becomes conductive, indicating that the discussion is dependent on specific definitions and assumptions about the lamp types.
poul
I think i have looked at like 20-30 web pages, and i can't find a simple step-by-step explanation of the operational principle.
I know, that when a rare gas like Helium, relaxes from an excited state two characteristic emission lines occur. But how do you excite the gas in the first place?
I know you can excite it, by shooting some electrons through the gas, but we have no free electron in the system, since the electric field should not be strong enough to ionize the helium atom by itself.
There are free electrons in the system. The electrons get accelerated by the electric field. Once the electrons are a high enough kinetic energy, the atoms absorb a discrete quantity from them in an inelastic collision, becoming excited. The unstable, excited atoms quickly fall back to a lower state, emitting a UV photon in the process. This UV photon interacts with the coating of the tube in a similar manner, transferring energy to excited/ground states, emitting visible light.
I read your post again, and I am not sure what you mean. You have no free electrons in a system you are doing? I am not sure how that would work in this case. All gas discharge lamps I know of have free electrons flowing through an ionized gas.
The (electrons in the) atoms can also be excited through inter-atom collsions.
okay so for a normal gas discharge lamp, we have free electrons you say. Are these made, by heating a filament or similar and then accelerated?
It depends on if it is a hot cathode or a cold cathode. Hot cathode lamps use thermionic emission to release the electrons from the electrodes to maintain conduction in the gas. Cold cathodes need an initial (much higher than hot cathode) voltage to ionize the gas and make it conductive.
Atmospheric gas is typically non-conductive until this "breakdown voltage" is applied. The voltage necessary is reduced in a vacuum and with certain gases, which is why these lamps have the gases they do.
