How does a one form relate to a vector field under a change of coordinates?
The discussion centers around the relationship between one forms and vector fields, particularly how this relationship is affected by changes in coordinates. Participants explore the duality between one forms and vector fields, the necessity of additional structures like inner products for establishing this relationship, and the implications of different coordinate systems.
  • Some participants propose that the relationship between one forms and vector fields requires an additional structure, such as an inner product, to facilitate the transpose operation.
  • Others argue that the choice of basis for one forms leads to a unique dual basis, but changing the basis can result in different vector representations for the same one form, raising questions about coordinate invariance.
  • A participant questions whether the notation and terminology used for one forms and vectors might be causing confusion, particularly in the context of linear functions.
  • Some participants discuss the implications of using different types of coordinates, including non-orthogonal and curvilinear systems, and how these relate to the concept of duality.
  • There is mention of the existence of techniques to establish equivalences between one forms and vector fields without relying on a Riemannian metric, although the relationship between partitions of unity and metrics is also explored.
  • One participant raises a specific question about the duality concept in the context of R3, seeking clarification on how the duality between a basis set and its reciprocal relates to the duality between vector fields and one forms.
Participants express multiple competing views on the necessity of inner products for establishing the relationship between one forms and vector fields, and the discussion remains unresolved regarding the implications of different coordinate systems and the terminology used.
Limitations include the potential misunderstanding of terminology related to one forms and vectors, as well as the dependence on the choice of basis and the implications of coordinate transformations.
Geometrick
One form <-----> vector field
How exactly does having a one form yield a vector field in a smooth way? I understand it's a duality relationship, but can anyone give me some more insight into this?
There isn't any intrinsic way; you need an additional gadget to do the transpose.
The most common way is to select an inner product (but any nondegenerate bilinear form will do), and the transpose is partial evaluation -- [itex]v^T = \langle v, \_ \rangle[/itex]. i.e. [itex]v^T(w) = \langle v, w \rangle[/itex].
Note that if you did have the transpose, reversing the above defines a bilinear form: [itex]B(v, w) := v^T(w)[/itex]
But, Hurkyl, I would believe that if one can define forms w_i on a space, one has chosen
a basis {w1,..,wn} for the space of forms. Once the basis of forms has been chosen, the dual basis is determined uniquely as the collection of linear maps L_i* with
L*_i(wj) =Del_i^j , where Del_i^j=1 if i=j, and it is zero otherwise. Then the
basis represetation of w in terms of the w_n's would uniquely determine w*. Or
did I miss or misunderstood ( or misunderestimate : ) ) something.?
Maybe the choice of inner product underlies the definition of L* .
Bacle, it's true that if you have a basis for the vector space then the usual dual basis is easily defined (as you mentioned using that delta), and so for any one-form you could potentially write out a vector that corresponds to it by having the same components (in terms of the basis and dual basis).
But if you then choose a new basis, and the corresponding new dual basis, then generally (I think except for bases related by orthogonal transforms) each such choice would relate a different vector to your same original one-form. We could say your procedure is not coordinate-invariant, and more specifically, it is equivalent to always assuming the canonical inner product two-form (or presuming every basis to be constructed of perpendicular normalised vectors). You may need to think beyond Cartesian space to see the issue with this.
L*_i(wj) =Del_i^j , where Del_i^j=1 if i=j, and it is zero otherwise .
I got a question about L*_i.
L*_i is a function that takes a form wj and maps it to a number. L*_i is also a vector. Would it be true that L*_i(wj) =wj(L*_i)?
I'm used to forms being linear functions of vectors. I'm not used to vectors being linear functions of forms.
Sometimes I see a vector V acting on a 0-form f as:
[tex]V[f]=V^i\frac{\partial f }{\partial x^i}[/tex]
So is it safe to say that if f is a function of the coordinates, then V[f] is as above. If f is a linear function of vectors, then
[tex]V[f]=V^i\frac{\partial f }{\partial x^i}=f(V)[/tex] ?
RedX said:
Would it be true that L*_i(wj) =wj(L*_i)? I'm used to forms being linear functions of vectors. I'm not used to vectors being linear functions of forms.
Maybe it's just terminology?
[tex]df[V] = \frac{\partial f }{\partial x^i} dx^i \left[ V^j \frac{\partial }{\partial x^j} \right]<br /> = \frac{\partial f }{\partial x^i} V^j \delta^i_j = V^i\frac{\partial f }{\partial x^i} = V[f][/tex]
That makes sense, but doesn't that only work for a perfect differential df, whose coefficients are [tex]\frac{\partial f }{\partial x^i}[/tex]? If df is not the differential of some function f, but instead a general 1-form, would you still write
[tex]df[V]= V[f][/tex]
only this time V[f] would not make sense as f is not defined, so write it as V[df], which is just the same as df[V]?
If a one form is not the differential of a function, you don't write it as [tex]df[/tex]. You use a single symbol such as [tex]\omega[/tex]. Note that the product [tex]\langle V,w \rangle = \langle w,V \rangle[/tex] is just an algebraic multiplication, and that by convention we say that [tex]\langle \partial_x, dx \rangle = \langle dx, \partial_x \rangle = 1[/tex] (i.e. the order does not matter).
Remember though that the differential of the inner product [tex]d \langle V, \omega \rangle[/tex] and Lie derivative [tex]L_V \omega = d \langle V, \omega \rangle + \langle V,d \omega \rangle[/tex] are not the same for general one forms, whereas, the result is compatible if the one form is closed or exact (i.e. can be expressed as [tex]df[/tex]), since the second term in the Lie derivative becomes zero ([tex]d df = 0[/tex] - so [tex]\langle V, d df \rangle = 0[/tex]).
A couple of points.
First there may not be a global basis for the 1 forms on a manifold.
If there is, the choice of basis is equivalent to the choice of a metric.
In general one passes - as Hurky says - from the 1 forms to vector fields through a metric.
Apparently there is a technique to get the equivalence without using the Riemannian metric, but just using a Partition of Unity. Having said that, I know that having a Partition of Unity implies the existence of a Riemannian metric, but the book I am using, a Riemannian metric is not even mentioned, it's a pure topological proof.
Any insight into this?
I think you only need paracompactness --which you get for free on a manifold,
by 2nd-countability and Local Compactness, I think-- to be able to define partitions of
unity. If your manifold is C<sup>oo</sup> , then it does admit a Riemannian
metric, tho I think this condition is too strong, i.e., it is sufficient but not necessary.
The proof I know for the existence of a Riemannian metric makes use of the PO unity:
you pullback the inner-product patch-wise and put it together globally using the POUnity.
I have a question relating to this discussion that I've been wondering about, and it pertains just to R3. Maybe this restriction is why I'm having problems with some subtle points.
If I define a general non-orthogonal and/or curvilinear coordinate system in R3 (i.e. a collection of basis vectors at every point in R3), there is a reciprocal (dual) set of basis vectors defined by the relation with the kronecker delta. In R3 at least, it is easily defined by an expression that looks like a cross product over a triple product for each of the dual e1, e2, e3. One could then use the Euclidian dot product to extract a covariant or contravariant component of each of these vectors.
My question is, how do we get the idea of duality between a vector field <-----> one form, from this description of using some frame field and its reciprocal to extract covariant and contravariant components of a vector in R3? Is the duality between a basis set in R3 and its reciprocal basis the same concept of duality discussed between a vector field and one form?
I replied to one of your earlier posts, and some of the concepts I covered may be useful for your question above, although I don't address the question completely. Note that a covector basis is essentially the same thing as a one form basis, and that often we define a set of coordinate functions, take the differential of the coordinate functions to get a one form basis, and use the kronecker delta relation you refer to to calculate the associated coordinate line basis. The duality relationship is more natural once you see how it is connected to the duality between coordinate functions and coordinate lines. The definition of the coordinate line and a discussion of the relation to coordinate functions is given the the post below:
Look https://www.physicsforums.com/showpost.php?p=2815042&postcount=6".
Hope this is useful because it really helps to be able to understand the relationship between the coordinate chart that is being used and the differential bases that are derived from the coordinate charts. It also helps to see how the chain rule plays a part in defining vectors and covectors and in the the transformations between coordinate charts.
please tell me what is meaning of dimension i knew only three dimension what about four ,five..... ialso want to know that any point in the three dimension is a vector than why we writing vector as a special case suppose u(2,3,5) is any point in the three dimension than why we writing it as a u=2i+3j+5K please reply me via email indetai
Alright everyone, I think I mostly understand my question above. Can anyone explain to me, however, the origin of the reason that the bilinear form from the matrix equation J(transpose)J gives you the Euclidian dot product of two vectors under a change of coordinates?
Okay, a few things here. I'm going to presume that you're at least a little bit familiar with what a vector space, dual space, differentiable manifold, tangent space, and cotagent space are (If not, Christopher Isham's book on differential geometry for physicists covers the topics rather concisely).To review (I'll get to your question in a moment):
1.) A tangent vector is simply an intrinsic direction, which a smooth curve can "point to" in at a given point in the manifold.
2.) The set of tangent vectors (all different ways to "point"), at a point, forms a vector space.
3.) You can, at every point, create another vector space which is dual to the tangent space at each point. These are called the cotangent spaces, and elements of cotangent spaces are called "one-forms."
Now, as it has been pointed out, you can construct a dual space from any given vector space by taking the set of linear transformations satisfying certain properties (this has been done in greater detail in Hurkyl's post), which is the usual way of doing it in linear algebra. However, as in linear algebra, there's a much more natural way of relating (via a natural linear isomorphism) using a non-degenerate bilinear form --the most common being inner products and symplectic forms.
Something analoguous is true for the the collections of tangent spaces defined on points on a manifold, only because now manifold deals with collections of vector spaces and dual spaces (tangent spaces and cotagent spaces) that are parameterized via points, we need to have them vary smoothly from point to point (to respect the differentiable structure). This is done using (psuedo-)Riemannian metrics and also symplectic forms.1.) However, we're not interested in individual tangent vectors or one-forms; we're interested in new objects called vector fields and differential forms. Vector fields are objects that take in points on a manifold and return vectors on the corresponding tangent spaces of those points, which vary smoothly from point to point. Now because of the rules of linear algebra and the natural isomorphism between vector spaces and their dual spaces gives a non-degenerate bilinear form (and a Riemannian metric, at each point, gives such a creature for each vector space and dual space at each point), it follows then that there is a natural relationship between each differential form and each vector field (given by the linear isomorphism, or more explicitly stated in RedX's post).
There's not really a "further insight" into this, other than to point out the difference in the transformation properties of one-forms and tangent vectors are all related via the geometry of the manifold (given by the Riemannian metric). They have other properties that are different but in certain sense, 'dual' (differential forms are necessary for integrating on manifolds and vector fields are necessary for taking derivatives of smooth functions on manifolds), but I'm afraid this sort of thing just is the way that it is. It's a matter of logic and cleverly chosen definitions.
I think the formula [tex]J^T J[/tex] is a little misleading. I will write this out using index notation since matrix format doesn't clarify the difference between upper and lower indices (vectors and covectors).
A metric can be represented as a symmetric matrix (or tensor) [tex]g_{j k} = g_{k j}[/tex] (i.e. switching the indexes is the equivalent of a transpose in matrix notation). If we want to convert this to a new coordinate system, we need to convert each index. The Jacobian is the equivalent of the chain rule transformation, and we need a Jacobian [tex]J_{i}^{j}[/tex] to convert the first index, and another Jacobian [tex]J_{m}^{k}[/tex] to convert the second index. The formula to transform the metric is [tex]J_{i}^{j} g_{jk} J_{m}^{k} = \hat{g}_{i m}[/tex] where [tex]\hat{g}_{i m}[/tex] is the metric on the new space.
For euclidean space, the metric is simply the Identity matrix [tex]\delta_{jk}[/tex], so we have [tex]J_{i}^{j} \delta_{jk} J_{m}^{k} = \hat{g}_{i m}[/tex]. For euclidean metric, the identity matrix can be removed leading to [tex]J_{i}^{j} J_{m}^{j} = \hat{g}_{i m}[/tex]. This is the [tex]J^T J[/tex] formula you identified. The index formula is not really correct because two upper indices can't be multiplied directly. The [tex]\delta_{j k}[/tex] is really needed, but this is dropped in the matrix formula you used. Anyway, it is really just a transformation of the euclidean metric (the identity matrix) to a new set of coordinates. Dropping the actual metric (the identity matrix) leads to some confusion about what you are doing.
  • · Replies 73 ·
10K
  • · Replies 26 ·
