How a pH Probe Works: A Comprehensive Guide
  • Thread starter Thread starter Daniel2244
    Ph Probe Work
A pH probe consists of two electrodes: a measuring electrode made of glass and a reference electrode, both submerged in potassium chloride (KCl) solutions. When the probe is immersed in a solution, hydrogen ions (H+) penetrate the glass membrane, leading to an ion exchange that generates a voltage. The reference electrode maintains a constant voltage, while the measuring electrode's voltage varies based on the external solution's pH. There are three solutions involved: the external solution, the internal solution of the measuring electrode, and the internal solution of the reference electrode, with only the external solution having an unknown pH. Understanding the function and interaction of these components is crucial for accurate pH measurement.
Daniel2244
How does a pH probe work?
A combined pH probe is comprised of 2 electrodes a measuring and reference electrode. The measuring electrode is composed of glass with a silver alloy electrical wire submerged into a neutral KCl solution contained in a membrane made of metal salts. Like the measuring electrode the reference electrode has a metal wire submerged into a KCl solution contained in the same glass put sepereated from the rest and has a junction.
When dipped in a solution the h+ ions in the solution penetrate into the wall of the membrane, causing an ion exchange producing a voltage (potential). At the reference electode the outside solution mixes with the interal neutral solution (somtimes called reference fill) at the junction, if the pH of the outside solution if different fdrom the pH of the inside solution a potential is produced,.
(This is where I get confused why are both of the solutions pH7 in the combined electrode? Shouldn't only one be a unkown solution).
The voltage at the reference eletrode is constant and the voltage produced at the measuring electrode varies depeing on the solution.
There are three solutions - external, inside, and inside the reference. Of these only one has unknown pH, exactly as you wrote it should be.
http://www.ph-meter.info/pH-electrode-single-double-junction
Likes Daniel2244
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
