How does a whip break speed of sound?
The discussion centers around the mechanisms by which a whip can achieve speeds that exceed the speed of sound, exploring various theoretical explanations and observations related to the physics of whip cracking. Participants examine concepts such as energy conservation, mass distribution, and the dynamics of motion in relation to the whip's structure.
  • Some participants propose that the whip's tip travels a longer distance than the arm during a crack, which contributes to its ability to reach supersonic speeds.
  • Others argue that the decreasing diameter of the whip from handle to tip allows energy to be concentrated, increasing the speed of the whip particles, though this explanation may not capture the complete picture.
  • A participant mentions observing slow-motion videos that suggest centripetal acceleration plays a role, as the radius of the loop decreases while traveling down the whip.
  • Another viewpoint suggests that the mass of the whip's line decreases as it becomes straight, implying that energy conservation leads to an increase in speed, although practical limits exist.
  • Some participants challenge the idea that tapering is essential for producing a whip crack, citing experiences with non-tapered leather cords that can also produce sound.
  • One participant references a source claiming that the loop traveling down the whip is responsible for the supersonic speeds, rather than the tip itself.
  • Another participant shares a link to an essay that discusses the physics of whip cracking, attributing the supersonic speed to a "chain reaction of levers and blocks."
Participants express multiple competing views on the mechanisms behind the whip's ability to break the sound barrier, with no consensus reached on a singular explanation. Disagreements exist regarding the significance of tapering, mass distribution, and the role of the loop in achieving supersonic speeds.
Some claims rely on specific assumptions about energy conservation and the relationship between mass and speed, which may not be universally accepted or confirmed. The discussion includes references to various models and experimental observations, but limitations in the explanations provided are acknowledged.
d4rr3n
I'm trying to understand by what mechanism a whip can multiply the velocity of the initial arm motion until it reaches the speed of sound, how is it doing this?
The end of the whip traces out a much longer distance than your arm, when going through one pass.
It has to do with the decreasing diameter of the whip, from the thick rope at the handle side to the very thin strands at he tip.
But the models to explain the details are not trivial.
A hand-waving explanation is the conservation of energy approach. As the whip becomes thinner, the same energy is distributed over a smaller mass so the speed of the whip particles increases. This is not wrong but it seems not to be the complete story.
I have been watching slow motion videos of whips cracking and the tip makes a loop traveling at speeds above that of sound. I was thinking it might be due to centripetal acceleration. The radius of the loop decreases as it travels down the whip.
The mass m of the whip's part of the line which wants to become straight (the rest) is proportional to its length L. With L converges m to zero at constant kinetic energy E = 1/2·m·v². Due to energy conservation v increases to ∞. For practical reasons v is bounded but big enough to break the sound barrier.
I have found that you can easily crack a leather cord with no tapering, therefore the belief that the phenomenon is due to the mass variance along the length of the whip is incorrect.
It's not the tapering, it's the throwback at the end of the line:
Without it, e.g. if you fix the end on the wall, you won't hear a bang.
Your "therefore" does not follow.
You can produce sound in many different ways. Most of them do not involve supersonic speeds.
If you look through the papers about the physics of the whip crack, you will see that the necessity of having supersonic speeds is not completely confirmed or accepted.
However the motion at speeds over speed of sound seem to be confirmed by both experiments and models.
The OP question was about what mechanism can explain the supersonic speeds and not about the relationship between these speeds and the whip crack.
True Cause of Whip's Crack Uncovered
http://www.scientificamerican.com/article/true-cause-of-whips-crack/
In the above they are saying it is not the tip that brakes the speed of sound but it is the loop traveling down the whip which is accelerating until it exceeds the speed of sound.
"The crack of a whip comes from a loop traveling along the whip, gaining speed until it reaches the speed of sound and creates a sonic boom,"
In the video I posted you can see the loop that they are talking about and you can also see that the radius of the loop is decreasing as the speed is increasing.
Here is an essay treating the physics of whipcracking. It explains the supersonic speed of the tip of the whip as a result of "a chain reaction of levers and blocks".
http://whip.creatingspeed.com
  • · Replies 17 ·
  • · Replies 236 ·
18K
  • · Replies 31 ·
  • · Replies 23 ·
