How does an electrical damper work.
An electrical damper functions by reducing the amplitude of current or voltage in a circuit, primarily through the principles of damping in RLC circuits. These circuits consist of resistors, inductors, and capacitors, which interact to create oscillations that can be underdamped, critically damped, or overdamped. The resistor in the circuit dissipates energy, leading to signal attenuation. Understanding these concepts is crucial for grasping the basic operations and applications of electrical dampers.
  • Basic knowledge of RLC circuits
  • Understanding of capacitance and impedance
  • Familiarity with electrical oscillations
  • Knowledge of energy dissipation in electrical components
  • Research "RLC circuit damping effects" for deeper insights
  • Explore "applications of electrical dampers in circuits"
  • Study "energy loss in resistors and its impact on circuit performance"
  • Learn about "oscillation behavior in underdamped, critically damped, and overdamped systems"
Electronics enthusiasts, electrical engineers, and students seeking to understand the principles and applications of electrical dampers in circuit design.
rigger100472
I am trying to find out how an electrical damper works. I know that it slowly reduces the amplitude of a current or voltage but don't know how, or even what any circuit would look like. I am not an electrician but know basics like capacitence, impedence etc so if you can help and can explain in laymans terms I would be grateful.
Everything I have looked at on the web is very specific but I am just after the basic idea and maybe some applications.
Thank you
Thank you
Do you mean electrical damping? For instance, a 2nd order system that can be underdamped, critically damped, or overdamped, based on the values of the resistor, capacitor, and inductor.
What UR_Correct said essentially. Google "RLC circuits". Current oscillates between an inductor and capacitor via a resistor. Physically this is an oscillation between an electric field(cap) and a magnetic field(inductor). The resistor is an energy loss resulting in signal attenuation (with the added smaller losses associated with the cap/inductor).
I Am asking about an electrical damper as UR_Correct has assumed.
Now I remember. RLC circuits are something I looked into once but didn't investigate their damping effect. Thanks everyone.:-)
  • · Replies 38 ·
  • · Replies 20 ·
