How does CMBR differ from ether (SR self study - Question from W. Rindler)
maverick280857
How does CMBR differ from ether (SR self study -- Question from W. Rindler)
Hello everyone
First of all, apologies for a previous post which was against forum rules. I was unaware that I had violated the rules by posting a link to a paper that wasn't from a proper peer-reviewed scientific journal (something I discovered much later).
Anyway, I have the following question, which is actually from Wolfgang Rindler's book on Special Relativity. This isn't homework (I'm teaching SR to myself).
If the universe were filled with a very rarified transparent fluid in which light propagated at speed c' < c, how would that affect special relativity?
The universe is filled with a diffuse 'photon gas' constituting the so-called microwave background radiation (a vestige of the 'big-bang' origin of the universe), which defines a preferred test frame at each point in the universe. How does that differ from an ether?
My random thoughts for each part...
Part 1: Unless light is known to interact with such a fluid, slowing it down or speeding it up, such a fluid will not affect special relativity.
Part 2: CMBR itself comprises of photons, whereas ether (nonexistent) is comprised of ___ (?). CMBR is itself radiation that travels at light speed, whereas ether is static. I know this may sound silly, but I wanted to discuss this part out here. I know CMBR isn't ether. But what really is the difference, formally? Also, what is the significance of this question?
Thanks and cheers.
Ether doesn't exist, it was ruled out by the http://en.wikipedia.org/wiki/Michelson-Morley_experiment" . CMBR was theorized to be created by recombination shortly after the big bang when it was cold enough for protons and electrons to couple and create hydrogen.
An ether is defined as something such as air except in a vacuum. In air sound travels, in an ether light would travel. In SR lorentz transformations are used because the speed of light is the same in all inertial reference frames. In an ether the speed of light would be non-constant in all inertial reference frames.
Also remember the speed of light is always constant, it does not speed up or slow down as classically described. On average when light passes through a medium it "slows" down by being absorbed and re-emitted
You're not alone. I got busted too. :smile:
Light has to interact with the fluid in order to "slow down" to c' (relative to the fluid), but this wouldn't change the invariant speed c. So the fluid has no effect on SR.
It still defines a rest frame, because you need to have a spefic velocity (by definition 0 in that frame) in order to observe background radiation with the same wavelengths from all directions.
The idea behind the aether was that it seemed reasonable to assume that a wave (anything that satisfies a wave equation) always consists of small displacements of the component parts of a medium (like when sound travels through air, or when ripples move across the surface of water). The question is significant because the answer means that the existence of this "preferred" rest frame doesn't invalidate the ideas behind SR.
Thanks psycherevolt and Fredrik.
(PS -- I was searching for this thread on the SR/GR forum.)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
