mindboggling
- 16
- 0
How does the inertial ball experiment work?
I’ve been trying to analyze and gain a greater understanding about this experiment, however I have I do not fully grasp how the system works.
as far as i can understand:
Also, how can I model and describe this experiment using mathematics? What equations can I use to explain “ how does the rate of force applied at the lower string affect which of the two strings break first”. More specifically if I were to graph the rate of force vs the tension in the upper and lower string, what questions can I use?
A classic and well-known lecture experiment, the inertial ball demonstration serves to demonstrate Newton’s laws of motion. The experiment consists of a heavy ball, suspended by a string, and an identical string that hangs below the ball. If the lower string is given a slow and steady pull, the upper string will eventually break under the additional force exerted by the hanging weight. However, if the lower string is given an abrupt jerk, the lower string will be the one to break.
The phenomena of the ‘inertia ball experiment’ can be explained in terms of Newton’s three laws of motion. The 3rd law of motion states that whenever object A exerts a force on another object B, object B will simultaneously exert a force on object A with the same magnitude in the opposite direction . Hence, when a force is applied to the lower string, the force is transferred along the string and exerts a force on the heavy ball. Assuming that the heavy ball is a stationary point, it will exert an equal and opposite force on the string. These two forces, exerted by the physical tug and exerted by the heavy ball on the string) causes tension in the string (as illustrated in the diagram). Similarly, the upper string experiences the tug at the lower string, but since the upper string has to carry the weight of the heavy ball, the tension in the upper string is greater than the lower string by the mass of the heavy ball multiplied by the acceleration of gravity.
However, different rates of forces can influence the rate of tension in the upper and lower string. Newton’s second law of motion states that the acceleration of an object is proportional to the net forces applied and inversely proportional to the mass of the object. Therefore, because the piece of string has far less inertia than the heavy ball, the lower string accelerates. As a result, the upper string does not experience as much stretch as the lower string and the tension does not increase as much.
