How Does Implicit Differentiation Apply to Polynomial Equations?
recoil33
Question:
y6 + 6 (x^2+4)6 = 9
6y5 .dy/dx . 6(x2 + 4)5 . (2x) = 0
6y5 .dy/dx = -6(x2+4)5 .(2x)
dy/dx = 6y5 / -6(x2 + 4)5 .(2x)
dy/dx = 6y5 / 12x(x2 +4)5
Although the answer is ment to have y5 as the numerator, not 6y5?
Another Q. [Simplifying result from product rule?]
Answer of the question:
6(x+4)5 .(x+2)7 + 7(x+2)6 . (x+4)6
It is possible to simplify the answer to
(x+4)6 (x+4)5 (13x+40)
Although, i don't see what to do to get this result.
Thanks in advance,
recoil33
thats not quite a question, though reasonably obvious you should explain what you are trying to do
so I am guessing you want to differentiate this implicitly?
recoil33 said:
Question:
y6 + 6 (x2+4)6 = 9
the first step should be
6y5 .dy/dx + 6.6(x2 + 4)5 . (2x) = 0
Ahh that makes sense, the source from which i got the question had a massive gap between the 6 and (x2+4)6 so i did not think to realize they were together.
Yes, i know the answers were obvious, although i could not see where i was going wrong.
Thank you.
i didn't mean the answer was obvious, just that i could work out what you were trying to accomplish
you'll generally get more help if you're clear describing what you are trying to do
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
