How Does Light's Speed Remain Constant in Moving Reference Frames?
The discussion centers on the question of how the speed of light remains constant when observed from different reference frames, specifically regarding a beam of light traveling towards a galaxy receding at 0.90c. Participants agree that the speed of light remains c for observers in the galaxy, regardless of the galaxy's motion. This principle is rooted in Einstein's theory of Special Relativity, which asserts that the speed of light is invariant across all inertial frames. The conversation also touches on the relativistic Doppler effect, suggesting that while the speed remains constant, the frequency of light would change due to the galaxy's motion. Overall, the consensus is that the speed of light is always c, affirming a fundamental aspect of modern physics.
gmsss
We send a beam of light, traveling at the speed of light c, toward a distant galaxy, which is receding from us with a speed of 0.90 c. Observers in the galaxy see the light coming toward them with a speed of ?
cant say
i think answer is "c" but don't know exact principle behind it
i tried "Doppler's effect in light" but that tell us about apparent frequency
and i don't know how to start now
Well, I won't pretend to be an expert in this but I believe you are right it should be "c" and I think it has to do with the idea that the speed of light is constant in all reference frames. I think Einstein came up with the idea as the basis for special relativity but someone else might like to come on here and correct me
I agree with Cherrybawls. I'm still no expert but I'm pretty sure of the answer. It's a postulate of Special Relativity.
More interesting would have been the question if they asked for the frequency of light, in which case you'd have to apply the relativistic Doppler effect.
This is what I think-
The galaxy is moving at a constant speed of 0.90c w.r.t earth. So it is an inertial frame of reference. Whatever is the speed of light on Earth will be the same in that galaxy too.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
