- 6,033
- 3,162
I mad the best case that I could for the idea of splitting the ## E ## into an ## E_s ## and an ## E_{induced} ## for the problem of a transformer coil operating at 50 or 60 Hz. Inside the conductor of the coil, we have a sea of electrons, and it should very quickly respond, in what would be a quasi-static type of charge redistribution, to any ## E_{induced} ## that would exist from a changing magnetic flux.vanhees71 said:Again: you cannot interpret these two parts of the electric fields physically since this split of the electric field is gauge dependent!
We have that ## \oint \vec{E}_{induced} \cdot dl=-\dot{\Phi} ##. For the type of symmetry we have in the problem with the long solenoid, with a uniform changing magnetic field over the circular area, I do believe we should be able to say that the amplitude of ##E_{induced} ## is ## \dot{\Phi}/(2 \pi r) ##, and if you want to call it ## E ## instead of ## E_{induced} ## for the free-space anywhere outside of the core where the magnetic field is changing, I do think there is sufficient symmetry to justify its computation. If we are not justified for this as a starting point, then I think we are indeed left with simply working with closed loops and calculating EMF's for those closed loops.
If we do have the starting point of an ## E_{induced} ## in the region where the conductive coil is present, the sea of electrons will give ##\vec{E}_s =-\vec{E}_{induced} ## inside the conductor coil. This then gives rise to the (integral of the) electrostatic ## E_s ## through any other external paths connecting the same two points, including through a voltmeter. The calculations are remarkably consistent, but it is really up to the individual whether it is deemed as good physics.
One item I did look to explain is how a voltmeter can measure what is an ## E_{induced} ##. If we are limited to writing it as an EMF in a closed loop, we certainly still have calculations that will get us the answer, (for what the voltmeter reads, etc.), but to me, introducing ## E_s=-E_{induced} ## in the conductor sheds some light on the problem.
With this though, I think I rest my case=you can either see some merit in looking at it in such a manner, or stick to the EMF's with closed loops as being the method you much prefer.
