How Does Positive Lift Affect the Ascent Rate of a Heavily Loaded Truck?
  • Context: High School
  • Thread starter Thread starter Syed F. Karim
    Buoyancy Lift Positive
The discussion centers on the effects of positive lift on the ascent rate of a heavily loaded truck attached to a helium balloon. When a one-pound rock is removed from a truck that has achieved neutral buoyancy, it gains a positive lift of one pound. However, due to the truck's significant mass, this lift results in a minimal ascent rate compared to a small balloon with the same lift. The relationship between lift and ascent rate is inversely proportional, as demonstrated by the formula a = f/m, where 'a' is acceleration, 'f' is force, and 'm' is mass.
  • Understanding of buoyancy principles
  • Basic knowledge of forces and acceleration (Newton's laws)
  • Familiarity with the concept of mass and weight
  • Knowledge of the SI system and imperial units (pound-force)
  • Research the principles of buoyancy and neutral buoyancy in fluid mechanics
  • Study the relationship between mass, force, and acceleration using Newton's second law
  • Explore the dynamics of lift in various objects, including balloons and aircraft
  • Investigate methods for calculating ascent rates of different masses in buoyant systems
Inventors, engineers, and physics enthusiasts interested in the mechanics of buoyancy and lift, particularly in applications involving heavy loads and ascent dynamics.
Syed F. Karim
Let's say that I rig up a truck to a giant helium balloon, but I load up the back of the truck with enough stones so that the truck has reached a state of neutral buoyancy--its just floating in mid-air, not rising not falling, just there. Now let's say I take away a one-pound rock from the truck's bed. Does the truck now have a positive lift of one pound? And will it now rise just like a small balloon with one pound of positive lift?
Yes, when the truck has neutral buoyency the forces acting on it perpendicalr to the ground are in equilibrium, by removing 1 pound you are removing 1 pound* from the downward force which means that there will be a net lift of 1 pound*.
* Isn't it pound-force? I I've never used anything other than the SI system in mechanics.
Yup. Pound-force.
- Warren
Yes it has positive lift of one pound, but No it does not rise just like a small balloon. It still has very large mass, so that one pound lift results in very small acceleration.
If a small balloon with a positive lift of one pound has an ascent rate of 1000ft/min, would a 1000lb-truck with the same one-pound positive lift have an ascent rate of just 1ft/min? Is it an inverse relationship? How do you calculate the rate of ascent of massive bodies? (This is not a homework problem, I am an inventor.)
a=f/m
  • · Replies 69 ·
16K
9K
  • · Replies 36 ·
  • · Replies 24 ·
