sodaMay
- 4
An outside observer will perceive my spaceship as being shorter, but what will i see of my outside surroundings? Will they be longer?
Depends what you mean by perceive. He certainly will not actually see it shorter. Only when he draws a choordinate chart he will conclude it is shorter.sodaMay said:An outside observer will perceive my spaceship as being shorter, but what will i see of my outside surroundings? Will they be longer?
In relativity there's a difference between what you see visually and what you measure in your own rest frame. What you see is affected by the fact that light from different events (or different parts of a single object) takes different amounts of time to reach you; the coordinates you assign to events are based on compensating for such delays, the usual method being for each observer to use a network of rulers and synchronized clocks at rest relative to himself, and defining the coordinates of events purely in terms of local measurements on this system (for example, if I see an explosion happen next to the 12-meter mark on my x-axis ruler, and the clock sitting on that mark reads 5 seconds at the moment the explosion happens next to it, then I assign that event coordinates x=12 meters, t=5 seconds in my frame).sodaMay said:An outside observer will perceive my spaceship as being shorter, but what will i see of my outside surroundings? Will they be longer?
The visual effects are symmetric. The 'distortion' seen by the outside observer as he looks at your spaceship will be the same as the 'distortion' seen by you as you look outside.sodaMay said:An outside observer will perceive my spaceship as being shorter, but what will i see of my outside surroundings? Will they be longer?
Terrell's paper pointed out that although special relativity appeared to describe an "observed contraction" in moving objects, these interpreted "observations" were not to be confused with the theory's literal predictions for the visible appearance of a moving object. Thanks to the differential timelag effects in signals reaching the observer from the object's different parts, a receding object would appear contracted, an approaching object would appear elongated (even under special relativity) and the geometry of a passing object would appear skewed.
I'd say the relativistic Doppler effect is the closest analogy; because of this effect, a clock moving towards you will visually appear sped up rather than slowed down, and a clock moving away from you will visually appear slowed down by a factor greater than the time dilation factor.Naty1 said:I had forgotton reading about this for the first time about a month or so ago and never got to post the obvious question: Is there an analogous effect for time dilation? Why?
