How does rotation have vectors?
  • Thread starter Thread starter NYGooner
    Rotation Vectors
Rotation is a type of motion that can be described using vectors, specifically angular velocity or angular momentum, rather than implying that rotation itself possesses vectors. The right hand rule helps determine the direction of these vectors based on the rotation's direction, with clockwise rotation corresponding to a downward vector and counter-clockwise rotation corresponding to an upward vector. However, this does not mean that any part of the rotating object, like a vinyl record, is moving in that vector's direction; instead, points on the record move tangentially along their circular path. The confusion often arises from misinterpreting the relationship between the direction of rotation and the vector direction. Understanding this distinction clarifies how vectors apply to rotational motion.
NYGooner
In my textbook they used the right hand rule to show that rotation has vectors instead of just being positive or negative relative to its direction of rotation of a vinyl record. In the image the record was going clock wise so by the right hand rule it was going downward which makes sense, but are they also saying that if it was counter-clock wise then by the right hand rule it would have a vector in the upward direction? Does that mean it would move upward? I'm sorry if this sounds dumb, I just can't understand how we can apply vectors to rotation.
There are a couple of inaccurately used words in your statement.
1. "rotation has vectors". Rotation is a type of motion. It does not "have" vectors.
2. "In the image the record was going clock wise so by the right hand rule it was going downward which makes sense". You said "it" was going downward. Ask yourself the question: What was going downward? Certainly not the vinyl record. It is NOT going downward. It is only going round and round.
3. There is a si,i;ar statement about counter-clockwise rotation.
The vector you are talking about does not give the direction of motion. Think of a tiny spot on your vinyl record. It is going round at the same rate as the record. At any instant, the spot is moving in a specific direction. That is the direction of the instantaneous velocity, and it is tangential to the circle in which the spot is moving.
The vector that the right hand rule shows is the ANGULAR VELOCITY, or ANGULAR MOMENTUM. Nothing is actually moving in the direction of these vectors. Rather, something is rotating around these vectors. The direction of rotation and the direction of the vector are related by the right hand rule.
Likes NYGooner
Sorry for the complicated wording, I just wasn't sure how to word this question. Thanks for clearing it up though, it makes sense now, thanks!
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 0 ·
  • · Replies 47 ·
