How effective are honeycomb plates at preventing "bend"?
  • Thread starter Thread starter Nikita240
    Bend Plates
This discussion focuses on the effectiveness of honeycomb plates in preventing bending for a custom ultra stiff strut bar design. Honeycomb plates are lightweight and exhibit anisotropic properties, meaning they are only stiff in specific directions, particularly the L direction where the honeycomb "ribbon" is woven. The technical data provided by manufacturers, such as Hexcel, is crucial for understanding the material properties and performance under bending forces. Users should consider the limitations of suppliers like McMaster, which may not provide comprehensive data.
  • Understanding of honeycomb material properties
  • Familiarity with anisotropic materials
  • Knowledge of structural engineering principles
  • Experience with custom automotive design
  • Research the mechanical properties of honeycomb materials from Hexcel
  • Explore the implications of anisotropic materials in engineering applications
  • Investigate design techniques for optimizing stiffness in automotive components
  • Learn about alternative lightweight materials for structural applications
Automotive engineers, materials scientists, and designers focused on lightweight structural components will benefit from this discussion, particularly those interested in enhancing stiffness while minimizing weight.
Nikita240
I'm designing a custom ultra stiff strut bar for a car. Achieving extreme stiffness usually adds a lot of weight, so I am looking into ways to reduce the weight.
Honeycomb plates are extremely light, but are only stiff in certain directions. This is perfect for my application since I am transferring forces in a very controlled manner.
My question is, how stiff are honeycomb plates under bend? That is, one side being held perfectly perpendicular, and a force applied tangentially to the other end.
Also, in what direction is the honeycomb strongest?
Thanks.
The manufacturers provide all the technical data you need to answer these questions, usually as the equivalent "smeared out" material properties ignoring the finite size of the cells.
For example see http://www.hexcel.com/Resources/DataSheets/Brochure-Data-Sheets/Honeycomb_Sandwich_Design_Technology.pdf
Honeycomb is anisotropic because of the way it is made, A set of flat strips are bonded together, and then pulled apart to form the cells, rather like making a Christmas decoration with paper and glue. This means the thickness is doubled where the strips are bonded. See the PDF for more.
I order from McMaster, and they don't provide that much detail unfortunately.
That is actually very helpful! Thanks!
After reading that, I understand that it's only strong in the L direction, which is the direction in which the honey comb "ribbon" is weaved.
  • · Replies 19 ·
12K
