How Far Can a Person Walk on an Overhanging Plank Before It Tips?
A uniform plank of 4.6 m and weight 210 N is supported at two points, with 1.1 m overhanging. A person weighing 448 N can walk a maximum distance of 0.56 m on the overhanging part before the plank tips. The tipping point occurs when the reaction force at the left support becomes zero, which can be calculated by equating moments about the right support. The center of gravity of the plank acts at 2.3 m from the left support, or 1.2 m from the right support. Understanding the moments and the position of the center of gravity is crucial for solving this problem.
wchvball13
A uniform plank of length 4.6 m and weight 210 N rests horizontally on two supports, with 1.1 m of the plank hanging over the right support. To what distance x can a person who weighs 448 N walk on the overhanging part of the plank before it just begins to tip?
W1(x1)=W2(x2) = Xcm
W1+W2
210(3.5) + 658(1.1)
210 + 448
Xcm=1.87m
Not even sure if this is right, and I'm stuck after this. The way I understand it, once the center of gravity passes the second support, the plank will start to tip. But I don't know how to figure out how to calculate how far the person can walk before the center of gravity gets to that point.
W1(x1)=W2(x2) = Xcm
W1+W2
210(3.5) + 658(1.1)
210 + 448
Xcm=1.87m
your moment calculations are way off. Hint: The plank will start to tip when the reaction at the left support goes to zero...does that help?
I don't understand...
W1(x1)=W2(x2) = Xcg
W1+W2
Is this the wrong equation?
W1(x1)=W2(x2) = Xcg
W1+W2
I don't know what you're trying to do with this equation which has some arbitrary numbers in it. When the left support reaction goes to zero, then the moment about the right support, from the cg of the planks weight, must balance the moment about the right support from the person's weight. Equate the moments and solve for the distance from the person to the right support. As he walks beyond that point, the plank tips because the left support cannot withstand an upward load (assuming its not bolted down, in which case she'd never tip).
ok I'm still completely lost...could you maybe baby step me through this?
The first step is to recognize that the planks weight of 210N acts at its cg of 2.3m from the left support..at its midpoint. So it acts at 1.2m to the left of the right support. So now equate moments about the right support, with the knowledge that the left support provides no support at the tipping point:
210(1.2) = 448(x). Solve for x, the distance to the right of the right support that the person must be for the beam to just start to tip. I get x= .56m. Aternatively, if you like your equation better and you understand where it's coming from, then with the cg of the system at the right support, you can sum moments about the left support and come up with
(210 +448)(3.50) = 210(2.3) + 448(3.5 + x), which yields the same result in a rather cumbersome manner. So why sum about the left support when it is much easier to sum about the right support
(210 + 448)(0) = 210(1.2) - 448(x) = 0; x = .56m.
Does this help or only serve to confuse?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
