How Far Should the Runner Sprint to Finish a 10km Race in Under 40 Minutes?
  • Thread starter Thread starter frog210293
A runner aims to complete a 10km race in under 40 minutes, maintaining a speed of 3.7 m/s before sprinting at 7.8 m/s. The initial calculations incorrectly estimated the time needed for the entire distance, leading to confusion about the sprint distance. The correct approach involves setting up an equation that combines the time taken at both speeds, ensuring the total time does not exceed 2400 seconds. Ultimately, the goal is to determine how far from the finish line the runner should begin her sprint to achieve the desired finish time.
frog210293
A runner is planning for a 10km race. She can maintain a steady speed of 3.7 m/s for as much time as needed before ending the race with a 7.8 m/s sprint. If she wants to finish in 40min or less, how far from the finish should she begin to sprint?
S = d / t
10 000m - distance
3.7m/s - speed
10 000/3.7
=2702.702s - time it would take if only running 3.7m/s
40*60= 2400s - time needed to complete the race in
2400s - 2702.702s
=302.702s
=302.7s / 7.8m/s
2361.075m - this answer is wrong. can anyone see what i have done wrong, thanks
The method is completely wrong. Moreover you have gone with different dimensions. Dividing time by speed does not give you distance.
Solve it for some time. That is, assume that after t seconds the girl will sprint. Then solve for t.
Ok then i didn't think it was going to be quite that easy but couldn't think of any other way to do it. So the equation should look something like t= (2702.702s - 2400s)*7.8m/s or is that basically making the same mistake still?
This time you are dimensionally correct but conceptually wrong. What is the logic behind it? Can't you follow the more traditional method.
The equation can be modeled this way:
(time it takes to run @ 3.7 m/s) + (time it takes to run @ 7.8 m/s) = (total time)
Use the equation t = d/r, with the appropriate values or expressions for d and r, for the two spots in the left side of the equation. The spot on the right side, total time, you know. Then solve for the distance. (I'm leaving some things out, I know. I hope you can figure the rest out.)
ok so we so 2703 + 1282.05 = 3985.05s
then d = s / t
d = 0.474 /3985.05s
d= 10000-9962.6
d= 37.4m from the finish? that doesn't sound right sorry i havn't done any sort of equations in a long time
Yeah this one is correct.
ok, thanks a lot otherwise i wouldn't of had a clue how to get this one right
is this the only answer for this question? its coming up as an incorrect answer sorry
then d = s / t
d = 0.474 /3985.05s
d= 10000-9962.6
No, no, that's not what I was getting at. Let me rewrite the model:
(time it takes to run x meters @ 3.7 m/s) + (time it takes to run ? meters @ 7.8 m/s) = (total time)
Given that t = d/r, the time it takes to run x meters @ 3.7 m/s would be
\frac{x}{3.7}
The time it takes to run ? meters @ 7.8 m/s would be
\frac{\text{?}}{7.8}
The total time is 40 min, or 2400 sec, so the equation becomes
\frac{x}{3.7} + \frac{\text{?}}{7.8} = 2400
Now I leave it to you to fill in the "?". If the runner runs x meters (out of 10km) @ 3.7 m/s, how many meters must she run @ 7.8 m/s?
I have no idea. now we have 2 variables to try and solve. once the ? is known then the rest is simple enough. As we basically have d/s + d/s and we know the speeds, i only need to find the distance she has to run at 7.8m/s as you said. so she runs x/10km at 3.7ms per second she then needs to make up the rest at 7.8m/s which is the remainder of that amount/10km?
