How far will an object travel on a flat surface
To determine how far a block will slide on a flat surface, one must analyze the forces acting on it, including weight and friction. A free body diagram can help visualize these forces, and applying Newton's second law will allow for calculating the block's deceleration due to friction. Using kinematic equations for constant acceleration, the distance traveled can be derived from the initial velocity until the block comes to rest. Additionally, considering the work-energy theorem can provide an alternative approach, equating the work done by friction to the initial kinetic energy. Understanding these principles will enable accurate predictions of the block's travel distance.
jtura
Hi there,
I am a physics idiot, but I still want to know where my object will end up ;)
Here is what I am trying to do:
I have a block that is sliding on a flat surface. I know the friction coefficient, the mass of the block, its initial position, gravity and initial velocity.
How can I determine the distance the object will travel? I have been reading posts and articles on wikipedia, but I can't seem to get it right.
distance = ?
Any help is greatly appreciated.
Cheers,
jt
1. Set up a free body diagram showing the forces acting on the block once it's moving. You'll have its weight and the frictional force opposing motion (which you can find assuming Coulomb friction).
2. Generate an expression that describes how the object will decelerate due to that frictional force if no driving force is acting upon it. Newton's second law will be helpful here.
3. Assuming the frictional force is constant, the object's deceleration will be constant. Use a suitable form of the 1D kinematics equations for constant acceleration to express the distance to decelerate from the initial velocity to rest.
4. Try and figure out where you've made assumptions that will cause your estimate to deviate from what you will see experimentally. There are probably quite a few!
Welcome to PF!
Hi jtura ! Hi RODNEYpaul! Welcome to PF! :smile:
To rephrase RODNEYpaul's advice …
use the work-energy theorem …
work done = energy lost …
so on a horizontal surface, the only work done is friction times distance, and when that equals the original kinetic energy, the block has stopped. :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
