How Fast Must Earth Spin for Zero Gravity at the Equator?
  • Thread starter Thread starter Allandra
    Field Force
The problem involves calculating the minimum period of rotation required for Earth to achieve zero normal contact force at the equator, effectively resulting in weightlessness. The context is rooted in physics concepts such as centripetal force and gravitational acceleration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relationship between gravitational force and centripetal force, questioning the implications of zero normal force on weightlessness. There are attempts to derive the period of rotation using the radius of the Earth and gravitational acceleration, with some participants expressing confusion about their calculations and the units used.
The discussion is ongoing, with participants exploring different interpretations of the problem and attempting to clarify their calculations. Some guidance has been offered regarding the use of standard units, but no consensus has been reached on the correct approach or final expression for the period of rotation.
Participants are working with specific values for the radius of the Earth and gravitational acceleration, but there is a noted confusion regarding unit conversions and the implications of their calculations on the expected outcome.
Allandra
1. Homework Statement
By considering the centripetal force acting on a man, calculate the minimum period of rotation that the Earth would need to have about its axis if a man at the equator were to experience zero normal contact force.
Take radius of Earth=6400km
2. The attempt at a solution
this means the g=Fc(centripetral force)
to find v= square root of ( radius of the Earth and g)
g=9.81 N/kg and then sub it to T= (2pie x radius of Earth )/v
Where is the error? Does a zero normal force means the person is experiencing weightlessness due to a=g?
OK, but you mean mg = Fc.
Where is the error?
I don't see any error. What your final expression for T?
Yes, that's what "weightlessness" means.
. where radius of the Earth is 6400km
But I can't get the ans=1.41hrs
I can only get 84.3hrs
square root of{Rg}=square root of (6400km X 35.3km/h)= 475
(R multiply by 2pie)divide by T= 40212/T
cross multiply them and I get 84.3hrs. Do u know where is the error?
When you converted g from m/s^2 to km/h^2, you made an error.
Instead, use standard units: meters and seconds, not km and hours. g = 9.8 m/s^2
When you find the answer in seconds, then convert to hours.
Thx Doc Al!:smile::biggrin:
  • · Replies 23 ·
  • · Replies 18 ·
