How Does GPS Determine the Best Route?
  • Thread starter Thread starter Likemath2014
    Gps
GPS determines the best route by first locating the user's position through signals from satellites. It then utilizes a built-in computer and map to calculate the optimal path, often employing algorithms like Dijkstra's for efficiency. The routing process can focus on various criteria, such as the shortest or fastest route, depending on user preferences. This optimization falls under Operations Research, which addresses complex routing problems. Understanding these components clarifies how GPS systems effectively guide users to their destinations.
Likemath2014
Hi there,
I am not sure if it's the right place to ask the question.
My question is how the GPS chooses the best way.
I mean where I can find something about its idea
Thx
Likes Likemath2014
many thanks, my question is the second part
Once the two end points are defined, this becomes an Operations Research optimization problem. You may want the shortest path, or you may want the fastest path (based on speed limits for each segment), or some other criterion. Operations Research is a well defined field dealing with such problems.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
10K
