How infinite does time get by gamma
zZhang
How infinite does time get by gamma...
So I was thinking, say you have a photon traveling at c. I would assume that the photon's own time frame would have time passing as normal. Now after a time t has passed in the photon's frame, some infinite amount of time would have passed say, on Earth by the time dilation equations, but that seemed a bit strange, from the light's point of view anyways, what would it "see" after a second or whatever in its own time? The universe come and gone? >.<
Then I thought about assigning different alephs to the set of time intervals traversed, but meh I'm now more confused that before. Help please! ;-)
Hi zZhang! :smile:
A photon could measure time and distance using its own wavelength as a "measuring-rod", I suppose.
So a photon can only really compare its own measurements with another photon's.
Comparing its own measurements with those of a slower-than-light observer doesn't make any more sense than trying to project something onto a screen when the angle of the screen to you is 0º - the ratios become infinite!
Yea that was the thing, that it didn't make any sense. Is there just no sense of time in the photon's frame?
Be a photon!
Well, as I said, the photon could measure time by using its wavelength - it should certainly be able to compare the lengths of different objects that way, and also to compare the wavelengths of other photons! :smile:
But unless you're thinking of becoming a photon yourself … :confused:
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
