How is energy conserved by magnet lifting a metallic object
In the scenario of a magnet lifting a metallic object, energy conservation is illustrated through the transformation of energy types. As the magnet lowers, the metallic object gains both kinetic and potential energy, while the magnet's magnetic field energy decreases. When the object comes to rest, its kinetic energy is converted into heat, dissipated within the magnet. The total energy in the closed system remains constant, as the work done on the object corresponds to the energy lost from the magnetic field. This demonstrates the principles of energy conservation effectively within the context of magnetism and motion.
tmhen
Assume a strong permanent magnet is suspended by a string over a metallic object. The magnet is slowly lowered until the object is attracted to the magnet. For this to occur the object acquired both kinetic and potential energy. Since the object comes to rest upon hitting the magnet, I assume the kinetic energy is dissipated as heat within the magnet. But considering only the closed system of the magnet and the object, the end result is a magnet that has acquired heat energy and an object that has acquired potential energy. Please explain how energy is conserved in this closed system.
Thanks for helping resolve this for a group of us with too much time on our hands.
The energy stored in the magnetic field is reduced. The reduction in the field's energy is equal to the work done on the object, both the work done increasing its KE and also the work done increasing its gravitational PE.
Likes davidbenari
Thank you for answering our question. Bunch of old guys to far removed from Physics 101. We apologize if this was too similar to other posts.
No problem! Let us know if you have any follow up questions.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
