How is Energy Conserved in a Mass-Spring System?
The discussion revolves around a mass-spring system, focusing on the conservation of energy principles to derive a differential equation. Participants explore the relationship between potential energy stored in the spring and kinetic energy of the mass, as well as the implications for motion and periodicity.
  • Participants discuss setting up the conservation of energy equation and its implications for deriving a first-order differential equation. There is exploration of the relationship between velocity and position, with some questioning the appropriateness of logarithmic versus exponential solutions. Others suggest that a second-order differential equation might be more suitable for capturing the oscillatory nature of the motion.
The discussion is active, with participants providing insights into the formulation of the equations and questioning the assumptions made in the initial setup. Some guidance has been offered regarding the handling of the conservation law and the implications of the first-order versus second-order equations.
Participants note that the problem specifically requests a first-order ordinary differential equation (ODE), which raises questions about the appropriateness of their approaches given the oscillatory nature of the system. There is also mention of the need to account for the positive and negative signs in the velocity equation.
Momentous
Consider a mass connected to a spring of sti ness k.
(a) Use conservation of energy to write down a first order differential equation obeyed
by the mass.
(b) Find the time t for the mass to move from the origin at t = 0 out to a position
x assuming that at t = 0 it has initial speed dx/dt = v0.
(c) Use the above to show that the period of motion is T = 2∏sqrt(m/k)
Us = .5kx^2
K = .5mv^2
a) I just set up a initial and final conservation of energy
I figured that I'd just set Us = K and make v = (dx/dt). That'd give me a natural log in my answer, which doesn't seem to make much sense.
Everything else doesn't seem to be too hard once I get part a.
That would be: $$\frac{dx}{dt} = \pm \sqrt{\frac{k}{m}}x$$ ... if you are looking for x(t) then the solution should be an exponential, not a log.
Notice that you can have a positive or a negative velocity for any given position.
Wouldn't that set up yield this...
dx/x = ±sqrt(k/m)*dt
and if you integrate...
ln(x) = ±sqrt(k/m)*t
I don't know much about eulers identity, but what if I took an exponential of that answer. Then it'd be
x = e^[±sqrt(k/m)*t]
which (and I know this part is wrong) I'd write as
x = cos[sqrt(k/m)*t]
If it were second order, then I could get the trig function that I think is supposed to happen from this with an ODE.
I feel like the problem lies in my first equation. Any thoughts on that?
Yes, the problem lies in the first equation. Energy is conserved means Us+K=C where C is some constant. Write that out then take the time derivative of both sides. That will give you a second order ode.
What Dick said - the clue is that you have not accounted for the ##\pm## ... didn't work: I should have just directed you to look again at what "conservation law" means ;)
The only thing I'm worried about is that the question specifically says to write down a first order ODE, but I guess it doesn't make much sense in this case.
So how do I take a time derivative of that? I'm a little confused because of the (dx/dt)^2
I'm guessing I want kx + ma = 0
wouldn't the chain rule get
d/dt(.5kx^2 + .5m(dx/dt)^2)) = kvx + mva = 0
... well done: cancel common factor?
Note: you have written down a 1st order ODE - this is the next step.
You could always have done: $$\frac{dx}{dt} = \pm \sqrt{c-\frac{kx^2}{m}}$$
... but you'd still have to figure how the ##\pm## should be handled.
  • · Replies 22 ·
