How is [itex]Q_s = M_s \times H_{fg}[/itex] derived?
  • Thread starter Thread starter fubarite
The discussion centers on the equation Qs = Ms * Hfg, which relates to the energy of steam (Qs), the mass of steam (Ms), and the enthalpy of vaporization (Hfg). This equation is crucial for understanding energy transfer in a university experiment involving steam. It highlights that when heat is added to a liquid at its boiling point, the energy primarily goes into vaporizing the liquid rather than increasing its temperature. The relationship between heat, mass, and enthalpy is established by noting that before reaching the boiling point, heat increases the temperature of the liquid (Q = m * cp * dT), while at the boiling point, heat is used for vaporization (Q = m * Hfg). Thus, the equation Qs = Ms * Hfg is derived from the principles of heat transfer in phase changes.
fubarite
I'm not fully sure if this would go in a "homework" section or the chemistry so I have posted in both.
basically the equation in the title is Qs = Ms times Hfg with
Q being the energy of steam, M being the mass of steam and H being the enthalpy as the saturated steam is between the state of liquid and gas.
This equation is involved in a university experiment of mine and I'd like to know where it's derived from as there doesn't seem to be a simple "energy = mass times enthalpy" expression, I know energy is equal to mass times the specific heat times change in temperature so are these two connected? And if the above is derived from that then how exactly?
Chemistry news on Phys.org
Sounds like you're dealing with some kind of vaporizer.
There are two things that heat can do when you add it to a liquid system:
-if the liquid is below its saturation temperature (i.e. boiling point), added heat will increase the liquid temperature (Q = mcpdT).
-once the liquid reaches its boiling point, added heat will vaporize some or all of the liquid. (Q=m(Hfg)
In your case, the liquid is already at its boiling point, so all of the heat energy coming in (i.e. Q) drives evaporation. So you can calculate the heat energy by multiplying the mass of generated steam by the energy required to vaporize it.
That's where the equation comes from.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
