How Is Terminal Velocity Achieved by a Ring Falling Through a Magnetic Field?
  • Thread starter Thread starter FelaKuti
    Magnet Ring
The discussion revolves around the dynamics of a cylindrical aluminium ring falling through a vertical magnetic field generated by a cylindrical magnet. Participants are exploring how to determine the terminal velocity of the ring based on the induced electromotive force (emf) and the forces acting on it, including gravitational and magnetic forces.
  • Mixed
  • Participants discuss the relationship between induced emf and magnetic flux, questioning the dimensions and appropriateness of their expressions. There are attempts to equate forces to find terminal velocity, with some participants expressing uncertainty about eliminating variables and the correct interpretation of the magnetic force direction.
Several participants have provided insights and clarifications regarding the equations used, particularly concerning magnetic flux and the application of the right-hand rule. There is ongoing exploration of the relationships between the variables involved, with no explicit consensus reached yet.
Participants are working within the constraints of a homework problem, which may limit the information available for solving the problem. There is a focus on understanding the underlying physics rather than arriving at a final solution.
FelaKuti
A cylindrical magnet with its axis vertical provides a radial magnetic field. A thin, circular aluminium ring that is co-axial with the magnet falls through the magnetic field.
By finding an expression for the current in the ring when it is falling at the speed v, or otherwise, determine the terminal velocity of the ring if the magnetic flux density at the circumference of the ring is 2.00T, and the ring has mass 2.66 x 10^-4 kg, radius 2.00 cm and R = 2.48 mOhms
Q from here: https://isaacphysics.org/questions/ring_drop?board=6e219139-c944-4b22-9a12-9a560fd199ce
induced emf = NdΦ/dt
W = mg
V = IR
Φ = BA
F = BIL
[/B]
If it reaches terminal velocity then weight downwards must equal magnetic force upwards. To work out magnetic force I need an equation for the induced emf so V = NdΦ/dt. I calculated the change in magnetic flux linkage as pir2 * v * dt * B.
Dividing by dt gives the rate of change of flux linkage which is pi * r2 * v * B which equals induced emf V.
Divide the LHS by R to give an equation for current, which I put into BIL and equate to mg. But I have a length l which I don't know how to eliminate whilst still being able to work out v, so I think my method here is wrong.
Does your expression have the correct dimensions for magnetic flux?
What particular length does L represent in the expression BIL? Does the expression BIL apply to this problem? If so, can you explain why?
Did you work out why the magnetic force would be upward?
So it should be magnetic flux = B * pi r2 for the right dimensions.
L is the length of a current-carrying wire, I thought it would apply to the problem because an emf is being induced in the ring that opposes the flux, and since it's a closed loop there must be current..
I think the magnetic force has to oppose weight for a terminal velocity to occur?
This equation is dimensionally correct, but it is not a correct equation for this problem. Magnetic flux is always associated with a surface area. Can you describe the area that you are working with?
If you've studied the concept of "motional emf", you might find it more appropriate for this problem than the concept of magnetic flux through a surface.
OK. You mentioned in your first post that you don't know how to "eliminate" L. Could you calculate the value of L?
Yes, that's right. But that doesn't explain why the magnetic force on the falling loop of wire is upward. You should be able to give an explanation based on your knowledge of the right-hand rules used to determine the direction of an induced current and the direction of the magnetic force on a current in a magnetic field.
The area would be the surface of the cylinder, so perhaps 2pi r2 + 2pi r v dt ?
Would the length then be v * dt perhaps?
For direction of the current, I have using the fleming's right hand rule the motion going downwards, the field going rightwards and thus the current would be coming out of the page, something like this?
If I use fleming's left hand rule from here I can see that the force acts upwards.
What area or areas are represented by the first term, 2pi r2? Is there any magnetic flux through this area?
I'm not sure what length you are referring to here. Is it the L in the expression BIL? If so, then the answer would be no. Previously, you stated correctly that L is the length of a current carrying wire. In this problem, identify the current-carrying wire. How long is it?
Yes. Good.
The cross-sectional areas I guess don't have flux running through them. So my area would just be 2 pi r * v * dt
Would the length of the current-carrying wire be the circumference of the ring?
Yes.
Yes.
now I've got V = B 2 pi r v dt / dt (change in flux over change in time, I guess I can cancel out the dts?)
I = 2 pi r v / R
using F = BIL with L = 2 pi r I get:
mg = B2 4 pi r2 v / R
still I've gone wrong somewhere
I = 2 pi r v / R
Looks like you have the right approach. In your equation for the current, I, you left out a quantity (but I think you put it in later). Your expression for mg looks almost right, but you missed a square of one of the factors on the right.
