How is the thermal conductivity affected by magnetic field?
The discussion centers around the potential effects of magnetic fields on the thermal conductivity of metals, specifically steel. Participants explore theoretical connections, existing literature, and the implications of related phenomena in materials physics.
  • Some participants question the relevance of magnetic fields to thermal conductivity, suggesting that they are not inherently connected.
  • Others propose that if a connection exists, it may be linked through mechanisms involving phonons and electrical conductivity, possibly leading to a concept termed "magnetothermoconductance."
  • A participant mentions that while the effect of magnetic fields on thermal conductivity is not standard in materials physics, it could be conceivable, especially in the context of spintronics and related phenomena.
  • One participant suggests that changes in resistance due to magnetic fields could influence thermal conductivity, as electrons are carriers of energy in metals.
  • There is a suggestion to investigate existing literature and specific terms related to magnetoresistance and thermal conductivity for further insights.
  • Participants share links to papers and articles that may provide additional context or information on the topic.
Participants express differing views on whether magnetic fields affect thermal conductivity, with some asserting a lack of connection and others proposing potential mechanisms. The discussion remains unresolved regarding the extent and nature of any such effect.
Participants note that if an effect exists, it may be very slight and not widely discussed in the literature. There are also calls for more specific details regarding the conditions under which the effect might be observed, such as temperature ranges and degrees of magnetization.
This discussion may be of interest to those studying materials physics, particularly in the context of thermal and electrical conductivity, as well as researchers exploring the intersections of magnetism and thermal properties in metals.
Seyit KAPLAN
Hello,
I'm searching for how magnetic field affects the thermal conductivity of the metal (such as steel in solid form). If someone suggests any article about it will be very helpful.
Why should it?
Vanadium 50 said:
Why should it?
If it doesn't, also why?
Welcome to PF Seyit. :welcome:
Why? Because they are not connected. That's not a very good question.
If such an effect exists, it is certainly not a standard part of materials physics. You could perhaps handwave an argument for it that electrical and thermal conductivity are related through phonon mechanisms, and electrical magnetoresistance is a thing, so perhaps thermal magnetoconductance is a thing? There is also the concept of spintronics and spinon conductance, where there might be something analogous to phonon heat transfer for spinons.
I surmised that such a phonemonon could be called magnetothermoconductance, and found one paper on it from 1992: http://jetp.ac.ru/cgi-bin/dn/e_074_03_0574.pdf It may also be mentioned in this paper, which I don't have access to right now: https://www.worldscientific.com/doi/abs/10.1142/9789812701879_0029 There was also one hit for magnetothermoresistance, where I just have the title: Thermoelectric properties and negative magnetothermoresistance effect in Te wires
Refining my search a bit to look at spintronics, I found this paper (and others) talking about magnetocalorimetrics, the relationship between magnetic and thermal effects: https://arxiv.org/pdf/1107.4395.pdf (arxiv because free, search for peer reviewed if you want). That paper has descriptions of the magnetic Pelletier effect, magnetic Seebeck effect, thermal Hall effect, which I think are up your alley.
So I guess to answer your question, it's conceivable that such an effect exists, but it's fairly obscure. The more serious treatment of spintronics is fairly new, so maybe give it a few years or decades.
I suppose it might, since it can affect the electrical conductivity. You could also probably fabricate materials that did have a connection between applied magnetic field and thermal conductivity, similar to how liquid crystals can be used to alter the optical properties of a material when an external electric field is applied.
Maybe start here and follow some of the references and add Google search terms to see where it takes you:
https://en.wikipedia.org/wiki/Magnetoresistance
BTW, is this question for a schoolwork assignment? It kind of sounds like one...
To the OP: google " thermal conductivity and magnetic properties in metals" and then ask questions as necessary. You can also substitute "ferromagnetic metals".
The effects are likely not very large.
Thanks for your kind and detailed reply, I already read some of these articles, but I couldn't find enough explanations.
First of all thanks for your reply, I'm studying on my PhD thesis, it is not directly relevant my subject, but i am quiete interested in physic. I already checked on wikipedia and followed all steps. You wrote that it can affect the electrical conductivity, can you explain how? Because i think it is quiete similar behavior to thermal conductivity.
Not sure about that. As the effect isn't discussed much, it would be very slight / negligible and these days, devices are designed to make use of almost any significant effect you could think of. I was thinking about the Hall effect, which would be related to 'effective' electrical conductance of a length of semiconductor - by deflecting electron flow. In substances where thermal conductivity is via electrons, the electrons would have longer curved paths (old model of course). Couldn't that affect thermal conductivity?
Can you say what field your PhD is in and what your background is in math and physics? That will help to guide how we frame our answers.
I got to the Magnetoresistance page via the Hall Effect page, since the Hall Effect in semiconductors is a pretty well-known effect, and seemed like it could be related to a change in resistance (because of current bunching). Have you read the Wikipedia article that I linked to? If so, can you ask specific questions about their description that is not making sense to you? Thanks.
If there is a change in the resistance, a reconstruction of the Fermi surface, or a change in electron scattering then there will be some change in the thermal conductivity because electrons are one of the carriers of energy in metals. Magnetic fields applied to metals can do all those things. The question is: how big is the effect? In most cases, I think the effect will be a tiny fraction of the overall thermal conductivity.
You are asking about steel. Could you be more specific about the situation you are thinking about, especially the expected temperature range and the degree of magnetization or applied field?
