How Is Torque Generated by Friction on a Rotating Disc Calculated?
3 replies · 4K views · last reply
johnysmithers
If I have a spinning circular disc of uniform density, how would I find the torque generated by friction, if the disc is lying flat against a table with coefficient of friction μ? τ=Fxr, but what is F, and what is r in this case?
Welcome to PF;
You use calculus ... divide the disk into narrow rings.
Thank you Mr. Bridge, for your reply. I am still confused however, as towhat the force on a differential element would be. The friction force would be μ N=μ m g(or would it be μ g dm?) The friction force would always act perpendicular to position, so torque would be upward with magnitude equal to the product of the distance from the center and the force. However, I am not sure what I would be integrating with respect to, and I am also unsure as to what the bounds on the integration would be. Please clarify? Thank you in advance.
That would be:
##d\tau = \mu g r \text{d}m##
The limits of the integration depend on how you define dm ...
hint: relate dm to dV (volume) and exploit the symmetry.
Friction force always acts opposite to the velocity vector.
Friction torque always twists the opposite way to the angular velocity.
