How is twin paradox resolved in case of no/zero acceleration?
San K
how is twin paradox resolved in case of no/zero acceleration/deceleration?
two twins one on Earth and other on a ship moving at constant velocity (say 80% speed of light).
the other twin does not turn around ..thus no acceleration/deceleration.
how we resolve the paradox now?
twin A will say twin B is moving..thus he/she should age slower
twin B will say twin A is moving...thus he/she should age slower
the paradox is traditionally resolved by the fact that one of them is accelerating/decelerating...because one of the twins has to turn around...etc
but in the case above (and we can build more scenarios) where there is only constant velocity...no acceleration...no turning around...
no meeting of the twins...
Hi San K! :smile:
no meeting of the twins, no paradox …
they have to start and finish together (or at least at the same velocity) to be able to compare ages at the same time :wink:
(if they have different velocities, two events at the same time for one will not be at the same time for the other)
For a numerical example of how this works, see the post linked below, and the post that it in turn links to:
https://www.physicsforums.com/showpost.php?p=3394389&postcount=8
You could make a special non-accelerated version of the paradox by using 3 clocks (A, B, C) instead of 2 twins. Clock A stays behind representing the stationary twin. The two other clocks are are moving with a constant speed in opposite direction of each other such that clock B first passes A and then C, and clock C such that it first passes clock B and then A. We then have three separate space-time events, let's call them AB, BC, and CA, where the clocks meet each other in pairs. In event AB we synchronize both A and B so they start with time zero, at BC we set clock C to same time as clock B, and at CA we just write down the value of clock A and C so we can compare them. Note, that we can compare the clock values of two clocks even though they move relative to each other because we allow them to "pass through" each other.
Calculating the relativistic distance between each successive pair of event you will end up with the expected result, namely that the proper time for clock A from event AB to CA will be larger than the proper time for clock B from AB to BC plus proper time for clock C from BC to CA.
Well, you still have a non-inertial path through spacetime being compared to an inertial path, both paths beginning and ending on the same pair of events. In SR, that is the fundamental requirement.
Why people fall for the triplet paradox always boggled me.
I can understand why people find "I see your clock going slower than mine, but you see my clock going slower than yours" paradoxical -- they haven't really grasped that the two facts aren't really comparable in the same way as if our clocks are sitting side by side. They haven't internalized that "I see" and "you see" are important.
I can understand why people find the twin paradox paradoxical. The amount of aging is now comparable, but they haven't internalized that "inertial travel" is a prerequisite for the qualitative fact that you see all* moving clocks running slower than yours.
But people that insist on the triplet paradox being paradoxical baffle me. As far as I can tell, they're so focused on defeating the usual resolution of the twin paradox that they simply don't notice they've also invalidated the (faulty) argument that leads to paradox.
*: Well, I mean properly calibrated clocks
I'm not sure what you mean?
I like this formulation of the paradox because it captures the essence of the twin paradox while still allowing only algebraic calculations using relativistic intervals from special relativity. Sure, you can also make an accelerated version but that requires integrals and is likely to have a more limited "audience" when you want to explain what is going in layman's terms.
I mean the essence of the twin paradox is gone! Vanished! No longer there!
You keep the closed loop, but I can't see anything that remains that someone might find paradoxical.
The only thing this version does is to "remove" the accelerating phase. You can imagine that the two clocks B and C representing the traveling twin with the accelerating turn-around phase left out, like if the twin brought a clock with him which he pauses just before he starts to accelerate back towards his brother back home and unpauses just when he stops accelerating; then clock B corresponds to the twin's clock on the outbound coast and clock C corresponds to his clock in the inbound coast.
You could also look at the non-acceleration scenario as a limit when acceleration of the twin goes to infinity. Assuming he can turn around using arbitrarily high acceleration, he can bring the time he spend doing the turn around arbitrarily close to zero. In the limit the twin will use zero proper time and distance to turn around and his clock will read like in the non-accelerated scenario.
To me, the non-accelerated version sound just as paradoxical as the accelerated version, especially since I think the paradox (the apparent contradiction that people feel must be present when they hear about time dilation) stems from the symmetry in stating that you will observe anyone moving relative to you as having time dilation. That two people can observe each others time as running slower do sound paradoxical until you start describing the full scenario that allow you to properly compare clocks.
It does remove something else significant -- the space-bound observer.
Notice that your post continues by considering the ordinary two-clock twin paradox, rather than discussing a three-clock scenario.
You didn't leave out the turn-around phase, you just paused the traveling twin's clock. There is still acceleration.
No, it replaces one observer (the traveling twin) with two observers (clock B and C). And, as I try to argue, you can even think of the two clocks as being "world line segments" of the same clock.
When looking at the time it takes to make the trip back and fourth the only part that is removed in the non-accelerated version is, well, the acceleration.
Notice that your post continues by considering the ordinary two-clock twin paradox, rather than discussing a three-clock scenario. You didn't leave out the turn-around phase, you just paused the traveling twin's clock. There is still acceleration.
In my reply to your earlier comment I outline how you can go from the ordinary twin paradox with an accelerated turn around to a simplified three-clock model with no acceleration that can be analyzed with relativistic intervals only and still get a "resolution" to the paradox. That is why I mention acceleration.
I am not sure what you think I am claiming. I am not claiming that you can make a single twin turn around without acceleration, or that the two scenarios will be identical. I merely say you can make a simplified version without acceleration and end up with a scenario where it is very easy to calculate the resulting difference in proper time between the various clocks and that this scenario is interesting as it can be thought of as an approach the accelerated scenario in the limit where the time used to accelerate becomes insignificant compared to the time used coasting.
You seem a little bend on marking the three-clock scenario as being "invalid" or "bad" in some sense. Does it accurately describe a twin rocketing around in a real rocket? No, it doesn't. Does it offer a resolution to the paradox of having symmetric time dilation? Yes, I believe it does.
In the three observer version, there is no round trip. If there is no round trip, the argument of the twin paradox is inapplicable. Auggie, the out-bound observer cannot compare his clock with Terra the terrestrial observer at the start end end of his journey. Neither can Indy, the in-bound observer. Only Stella the space-bound observer who hitches a ride with Auggie then switches over to Indy's ship as it passes by is able to compare clocks with Terra.
If there is a round trip, there is acceleration. (be it smooth and prolonged, or infinite and instantaneous.
There is the "round trip" of proper time intervals, which (to me) is all that matters. You can make an accelerated scenario, cut out the acceleration to get a non-accelerated version and then still have an explanation through calculations as to why one twin will be older than the other. Makes perfect sense to me.
But I guess you don't consider the resolution of the paradox using Minkowski diagrams [1] valid either then?
[1] http://en.wikipedia.org/wiki/Twin_paradox#Resolution_of_the_paradox_in_special_relativity
tiny-tim said:
Hi San K! :smile:
I don't see any reason why twins have to start and finish together or why the twins should meet at all? The paradox still remains as both twins observe time dilation in other frame. Both twins are also in inertial frames and thus SR must then hold.
I was going to post the same question in PF but I am glad that someone else thought like me. In the classic explanation of twin paradox, this argument is swept under the carpet by assuming that one twin must accelerate and decelerate. Since we don't know what an accelerating and decelerating observer will observe or God forbid some mind-numbing GR tensor equations are brought into consideration, a simpleton is browbeaten into believing that the twin in the rocket will observe the same as the twin on earth. I think this twin-paradox problem is very important as it raises the question of internal consistency of SR.
I think Hurkyl is inviting you to consider the "triangle paradox". The "triangle paradox", usually called the triangle inequality, basically says that if you sum two sides of a triangle, the result will be greater than the third side - and equal only in very special cases. It does with distances what the twin paradox does with times, with one important difference. In the "triangle paradox" aka the triangle inequality, the sum of the distances is greater than the straight-line path, in the "twin paradox", the sum of the times is lesser than the straight line path.
The fact that the sum is lowest is a bit weird, compared to euclidean geometry, but the point is that if you believe that Euclidean geometry is self-consistent, it's not that hard to picture space-time as having a similar, consistent geometry. The only thing that really has to go is the notion of observer-independent simultaneity.
i quote two that i think i agree with...so i question it further to understand it better...
tiny-tim said:
Hi San K! :smile:no meeting of the twins, no paradox …
hi tiny (but mighty?) tim...:)
you mean one cannot compare because they are not comparable frames of reference?
that have to be at same velocity and place? can put it more precisely?
why are they not comparable?
even if they are not comparable, don't we still have to resolve the issue about...
one twin saying that the other is moving...so he is ageing faster, not me...
and the other twin saying the same thing
or are both the twins right?...till they meet...and it depends who ends up visiting whom at what speed/place/time etc...
i mean..how do we resolve...who is moving? i guess the answer is...we cannot say...who is moving...
unless and until...we get them in the same frame of reference...
is the below statement correct? if not...then modify it to make it correct
you cannot compare any arbitrary frames of references.
..to compare any two events...they have to be in same frame of reference...or "normalized/adjust/accounted-for" to be in the same frame of reference...is that ...why we say...space-time
being at different space/speed...can mean different time?
space and time...are...in a sense...interchangeable?
hi hurkyl, can you write a few more sentences that can help folks internalize "inertial travel"?
"Inertial travel" means that you are traveling in a manner such that an accelerometer attached to you reads 0 at all times. If you aren't traveling inertially then "your frame" is non-inertial and so the "usual" physics equations are not correct. Once you have realized that then it is clear that there is no twin paradox.
case where: one twin moving at constant velocity and the other stationery
the twin that is moving will have velocity and hence momentum...
however you cannot tell between two twin who is moving...relative to the other twin....
when we have only two frames of references...
however if you have a third (or a forth or fifth) reference point, you could tell...
is the above correct?
hi dale
in the example i initially gave...both the frames would be inertial frames...then
is there no twin paradox because the stationary inertial frame (for twin A) is not comparable with the constant velocity inertial frame (for twin B)?...because they can never meet?
note: acceleration in both cases is zero because one is stationary and other is moving at constant velocity
There are two problems:
  • This isn't a resolution of the twin paradox -- you've changed the scenario to eliminate a key component to the (flawed) derivation of paradox.
  • Some people find the triplet paradox paradoxical, and you've claimed it's equally paradoxical to the twin paradox. Tell me, what is paradoxical?
You seem to have totally and completely missed the idea of what it means to be a "paradox". The problem is not that people are asking "How do I compute that one twin ages less than the other" -- the problem is that people are asking "I've done the computation two different ways and have contradictory answers!"
Correct.
There is no paradox because everything is symmetric. There is nothing to distinguish A from B, and so both A and B make symmetric measurements regarding themselves and each other.
The number of reference frames is not relevant in any way. Velocity is relative regardless.
Hurkyl said:
Tell me, what is paradoxical?[/list]
My idea of paradox in this context is exactly as it explained in the Wikipedia page [1] that I referred to in my previous post regarding explaining the paradox using a Minkowski diagram (a question you ignored, by the way). Let me quote two passages from it that sums it up for me:
In physics, the twin paradox is a thought experiment in special relativity, in which a twin makes a journey into space in a high-speed rocket and returns home to find he has aged less than his identical twin who stayed on Earth. This result appears puzzling because each twin sees the other twin as traveling, and so, according to a naive application of time dilation, each should paradoxically find the other to have aged more slowly.
and
The paradox centers around the contention that, in relativity, either twin could regard the other as the traveler, in which case each should find the other younger—a logical contradiction. This contention assumes that the twins' situations are symmetrical and interchangeable, an assumption that is not correct.
If you use some other "definition" on what the Twin Paradox is all about, then we have to disagree. In the sense described by the above quotes, I still claim the three-clock scenario brings a resolution to the paradox. The paradox (the apparent symmetry) is resolved by noting that the situation is not symmetric after all, not even if you leave out acceleration, and that you can easily calculate the difference in proper time intervals of the clocks using simple algebraic equations.
I do not and have not claimed the two scenarios to be (physical) equal. What I have been claiming, though, is that is that with regard to the calculation of proper time intervals for the two twins you can consider the three-clock scenario a limiting case of the accelerated scenario where the acceleration is arbitrarily high. Do you disagree with that?
If you still want to discuss this outside your assumption that I have "totally and completely missed the idea" of what this is about, then it would also be nice to know if you consider the explanation using Minkowski diagram a valid resolution of the paradox?
Yes you are correct.
The paradox still remains: Both twins see that they age faster than their counterpart.
But that is not a paradox. They are symmetric so you would expect them to see each other's clocks symmetrically. Any other result would be paradoxical.
The symmetry is broken because the twins are in different inertial frame. Each twin should observe time dilation in others frame. I know this result is counter-intuitive and paradoxial but this is what relativity says.
Different inertial frames are indistinguishable, so that is symmetrical also. I think you have a misunderstanding of what makes a situation symmetrical or not.
What about time dilation due to relative velocity of the observers/twins.
That is completely symmetrical, they each observe the other to be dilated by the same amount.
  • #31
Different inertial frames are distinguishable because they are moving at different speed. If inertial frames were indistinguishable, they must be equivalent and not relative. But we don't have Theory of Equivalency instead of Theory of Relativity.
  • #32
If each twin observes other twin's time to be dilated, how can their time be same?
  • #33
Follow the link in post #3 of this thread.
  • #34
San K said:
Hi San K! :smile:
people who are further away look smaller :wink:
if A is a long way from B, then A says "B looks smaller", and B says "A looks smaller" …
where's the paradox??
there would only be a paradox if A was standing next to B (or if they were moving past each other, but they make their measurements at the exact moment they are passing) …
then it is paradoxical for each to regard the other as shorter
(of course, that paradox does exist … it's called the Lorentz-Fitzgerald contraction! :biggrin:)
similarly, there's no clock paradox unless the two clocks start at the same velocity, and finish at the same velocity (position doesn't matter) :smile:
  • #35
You cannot resolve a paradox by justifying one half of the contradiction. You have to explain why the other half of the contradiction is invalid.
A resolution of the twin paradox has to explain what is wrong with the argument
Stella sees that Terra is moving with respect to her, and thus her clock running slowly for the entire trip. Therefore, when Stella returns home, she finds that Terra's clock reads less time than Stella's clock does​
Showing an asymmetry does not demonstrate a flaw with the above argument. It simply defeats the supplementary argument that Terra and Stella's points of view are indistinguishable.
One can hope that demonstrating the asymmetry, or that providing a correct way to compute things, could prompt the confused person into resolving the the paradox himself. But you also risk the rather dangerous possibility of pushing the person into accepting doublethink -- to accept the resolution despite retaining the belief that there is nothing actually wrong with the argument above.
  • #36
They aren't the same, they are symmetric. You don't seem to understand symmetry.
  • #37
Excellent example of symmetry!
  • #38
So, if I understand you correctly, you are saying that people who wants to resolve the paradox and are shown, quantitatively, that the Lorentz transformation of suitable events can explain and give the actual number of the difference in the twins age, these people will still in some meta-physical way believe there is a paradox unless they are presented with a much more complicated explanation that includes acceleration? If so, I don't find that very plausible. There is no doubt that changing from an outbound to an inbound trajectory is central to the resolution, but exact nature of this change is (in my book) not essential.
I don't think I can bring anything new to this discussion at this point, only repeat what I have already said. You seem to skip or ignore the specific questions I've ask you so far, so unless you feel like answering some of them I really don't see us getting any further.
  • #39
Yes. You are explaining to them information they already have (Terra ages more than Stella), and offer absolutely no insight as to why other information they have (Stella ages more than Terra) is faulty.
That would be even worse!
I've answered everything I thought was relevant. But since you insist:
I agree in the sense that you are considering two identical mathematical calculations. I disagree in the sense that three clocks is not a limiting case of two clocks.
It depends on what you do with the diagram. Wikipedia's resolution is fine. It sports a feature your argument does not -- a demonstration of where and how the rationale "Stella sees Terra's clock running slowly the whole trip" is faulty.
Was there another question youw anted answered?
  • #40
Well, I think I can see what you are getting at then. You are worried that by only showing the three-clock scenario with its associated simple calculations people would still be at loss as to the nature of the break in symmetry, that is, they would still not know the "reason" for why Stella ends up younger and not vice versa. In the words used on the Twin Paradox FAQ [1] the three-clock scenario leaves a "time gap" which I do concur seems very mysterious unless it is also explained what it "really looks like" in a scenario with acceleration.
If this was your point, then I agree. Personally I feel that the three-clock or instantaneous turn-around scenario explains a lot and that change of reference frames itself is the essential part, but I can see why some would feel something important has been left out. If I were to explain this to, say, my 15 year old kid I'd show her the three-clock version with its simple calculations and then in parallel or afterwards extend the explanation (but not the calculations) to include acceleration of material bodies so that we could make an actual twin take the trip. In fact, this would be a fun vacation exercise.
Not unless you think I've missed your point above.
[1] http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html
  • #41
Distant object looks smaller because they subtend smaller angle in the eye. Distant object looking small is just an optical illiusion, the object still has the same size. Do you believe that distant star comes closer when you see through telescope?
  • #42
Symmetry is a property of geometrical figure having a mirror plane.
Time is a scalar quantity.
Saying time is symmetric is like comparing oranges to apples.
I don't get what you mean by time is symmetric. Perhaps you can express it mathematically what symmetric time means?
  • #43
Clearly. But why do they BOTH subtend smaller angles? How come one doesn't subtend a smaller angle and the other subtend a larger angle? The answer, unsurprisingly, is symmetry.
Symmetry is more general than that. Mathematically and physically symmetry means that something does not change under some specific transformation. For instance, an equilateral triangle is symmetric under 120º rotations about its center because it is unchanged by that transformation.
In the case of the example above with distant objects, A and B, looking at each other the angle subtended is determined by Euclidean geometry which is unchanged by rotations and translations. Since A and B are related to each other via a rotation and a translation they are symmetric, meaning that the geometry is also unchanged by transformation of swapping A with B. Therefore, if the angle subtended by A decreases for B then by symmetry we can swap A and B and state that the angle subtended by B decreases for A.
In the case of relativity (either Galileo's or Einstein's) it is a fundamental postulate of the theory that the laws of physics are unchanged by boosts. So if A and B are related to each other via a boost then they are symmetric and in any statement you can swap A and B and have an equally valid statement. So if A's clock is slow according to B then by symmetry B's clock is slow according to A.
Do you feel like you understand the important role of symmetry a little better now?
  • #44
lovetruth said:
… Distant object looking small is just an optical illiusion, the object still has the same size.
Yes, and a moving clock going slower is also just an optical illusion …
do you really think that a moving (non-accelerating) clock is actually going slower? :rolleyes:
btw, the Lorentz-Fitzerald contraction is an optical illusion too …
do you really think that a moving train actually changes shape? :wink:
  • #45
I don't want to be pedantic here, since I agree with essentially everything you have said. However, I don't like your usage of the word "actually". It seems to present the idea that something is a particular way objectively. And speaking about SR, since essentially every interaction is mediated by photons, I am okay with saying that these phenomena are "optical" (the measurements/interactions/observations are all described by classical optics) however, deep down there is no pure version of the train. But, I am willing to hear out a counter argument to this idea if you think different.
  • #46
tiny-tim said:
Hi San K! :smile:
No, just have them take pictures of themselves they can compare later when they meet up again. :) same result will happen though. The spaceship twins picture will show him ageing at a slower rate.
  • #47
No, this is false. While each is moving away from the other, pictures will be identical. Again, think about symmetry. Just as each sees the other getting smaller, each sees and photographs the other's clock going slower.
The symmetry goes away only if one of the twins changes direction. Then, the one that changes direction immediately sees a change in clock rate of the other; while the one that remains inertial only sees the other change clock rate after a delay. This is what would lead to a consistent correlation of the movies after both twins are together again.
  • #48
This is not ever true in any scenario, regardless of their motion. How could it possibly ever be true? If they take a photo every year according to their own clocks then they will be a year older in every photo.
In the standard twins paradox (or any other asymmetric scenario) what will differ is the number of photos, not the apparent age in the nth photo.
  • #49
Good point PAllen and DaleSpam. That's what I was thinking.
The time-space for both, Earth and ship, are different.
Now if we take photos according to a third stationary (or for that matter the stationary "earth") clock say at times...noon, 1 pm, 2 pm...etc i.e. per the Earth's clock time and for now ignore the clock time on the "moving" ship.
a) what would we notice about the photos?
if we take photos per the "moving" ships clock and ignore the "stationary" Earth's clock time
b) what would we notice about the photos?
Note: I know that that comparing photos this way might not be "complete" (for the purposes of showing the consistency of relativity) since we are not accounting for other things.
  • #50
A clock doesn't make a reference frame -- you need a way for observers to decide what the clock says "now".
e.g. if Stella flies past the sun and uses her telescope to look at the clock on Earth, when does she take the "1 PM" photograph"? When she sees "1:00" on the clock through the telescope? When she sees "12:52" (minus a few seconds)? Some other scheme?
(note: The sun is just over 8 light-minutes away from the Earth)
