How Many Abelian Groups of Given Order
  • Thread starter Thread starter darkchild
    Groups
darkchild
Integrating Floor Function
If \lfloor{x}\rfloor denotes the greatest integer not exceeding x, then \int_{0}^{\infty}\lfloor{x}\rfloor e^{-x}dx=
none
I don't know how to start this problem. At first, I tried bringing the floor function outside of the integral and using a summation because it only takes on discrete values, then I realized that those discrete values get multiplied by the exponential infinitely many times as x varies from any integer to the integer that is one greater.
I've tried the product rule. I looked up both the derivative and the indefinite integral of the floor function. If I use u=\lfloor{x}\rfloor, du=0 and I get back the original integral. If I use dv=\lfloor{x}\rfloor, the integral just gets more complicated.
You aren't going to have much luck with the usual analytic techniques. Integrate it over the interval [n,n+1] for n an integer. So the floor function has a definite value. Then sum over n.
The problem I'm having is that I can't integrate this at all. I'm not even at the step where I fiddle with the limits of integration/take sums yet.
You can't integrate a function like f(x)=n*e^(-x) where n is a constant? What's the integral for x=2 to x=3 of floor(x)*e^(-x)? Where I'm writing 'floor' for the function instead of the funny brackets.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
