How many kg of ice must be dropped to make Tf= 22.7C?
To determine how much ice at -19.6 °C is needed to cool 0.3 kg of water from 78.6 °C to a final temperature of 22.7 °C, the heat transfer equations must account for both the warming of the ice and the cooling of the water. The initial calculations incorrectly separated the melted ice from the warm water, failing to consider that they mix after the ice melts. The correct approach involves combining the masses in the heat transfer equation for the warm water and the melted ice. Adjustments to the equations are necessary to reflect that the warm water cools down while the melted ice warms up to the final temperature. The final solution requires careful integration of all heat transfers to achieve the desired temperature.
madison222s
An insulated beaker with neglible mass contains .3kg of water at a temp of 78.6 C. How many kg of ice at -19.6 C must be dropped into the water to make Tf= 22.7C?
Specific heat for water= 4190 J/kgK
specific heat for ice= 2100 J/kgK
heat of fusion for water= 334kJ/kg
Q=mc(Tf-Ti)
Q=mL
Q1 = bring ice to 0 C
  • Q=micec(Tf-Ti)
  • Q=mice(2100 J/kgK)(0-19.6)
  • Q= 41160mice
Q2 = melt ice (phase change)
  • Q=mL
  • Q=mice(334000 J/kg)
Q3= cool down water
  • Q=mwaterc(Tf-Ti)
  • Q=(.3kg)(4190 J/kgK)(22.7 - 78.6)
  • Q=-70266.9 J
Q1+Q2+Q3=0
41160mice + 334000mice + (-70266.9)=0
375160mice= 70266.9
mice = .187kg
This answer isn't correct. What did I do wrong or what did I miss? I'm thinking maybe I missed another Q but I don't know what it could be.
Q=mc(Tf-Ti)
Q=mL
  • Q=micec(Tf-Ti)
  • Q= 41160mice
  • Q=mL
Q3= cool down water
  • Q=mwaterc(Tf-Ti)
  • Q=-70266.9 J
Q1+Q2+Q3=0
375160mice= 70266.9
mice = .187kg
Remember, once the ice melts, the liquid from this mixes with the liquid already in the beaker.
The final temperature of 22.7 °C must be reached by all of the liquid in the beaker.
Then would Q3 have to include both the masses?
Yep. You can't separate the melt water from the warm water already in the beaker when the ice was dropped in.
So then its
Q3=(mice+mwater)c(Tf-Ti)
=(.3kg + mice)(4190)(22.7-78.6)
=(.3kg + mice)(-234221)
= -70266.3 - 234221mice
And then add this Q3 to the others and set =0?
madison222s said:
So then its
Be careful here.
The warm water in the beaker is being cooled from 78.6 °C to 22.7 °C.
The melt water is being warmed from 0 °C to 22.7 °C.
Your equations should reflect this.
SteamKing said:
Be careful here.
So what I really need is 2 extra equations then?
No, nevermind. Just one. For the ice water. Q4= micecice(22.7-0)
Remember, the ice has already melted. cice should be cwater.
Oh of course. Ok I got it, thanks!
