How many number of IP addresses are available?
Phys12
Counting Internet Addresses In the Internet, which is made up of interconnected physical networks of computers, each computer (or more precisely, each network connection of a computer) is assigned an Internet address. In Version 4 of the Internet Protocol (IPv4), now in use, an address is a string of 32 bits. It begins with a network number (netid ). The netid is followed by a host number (hostid ), which identifies a computer as a member of a particular network. Three forms of addresses are used, with different numbers of bits used for netids and hostids. Class A addresses, used for the largest networks, consist of 0, followed by a 7-bit netid and a 24-bit hostid. Class B addresses, used for medium-sized networks, consist of 10, followed by a 14-bit netid and a 16-bit hostid. Class C addresses, used for the smallest networks, consist of 110, followed by a 21-bit netid and an 8-bit hostid. There are several restrictions on addresses because of special uses: 1111111 is not available as the netid of a Class A network, and the hostids consisting of all 0s and all 1s are not available for use in any network. A computer on the Internet has either a Class A, a Class B, or a Class C address. (Besides Class A, B, and C addresses, there are also Class D addresses, reserved for use in multicasting when multiple computers are addressed at a single time, consisting of 1110 followed by 28 bits, and Class E addresses, reserved for future use, consisting of 11110 followed by 27 bits. Neither Class D nor Class E addresses are assigned as the IPv4 address of a computer on the Internet.)
How many different IPv4 addresses are available for computers on the Internet?
The Sum Rule: P1 + P2 + ... Pn
The Product Rule: P1 * P2 * ...Pn
Considering that a person can either have a class A IP address or a class B IP address or a class C IP address, the number of IP addresses will be (number of class A IP addresses + number of class B IP addresses + number of class C IP addresses).
Total number of class A IP addresses = total number of possible addresses - total number of forbidden IP addresses. Since the netid is of 7 bits (the first bit is fixed) and the hostid of 24, total number of possible addresses = 2^7 * 2^24. Now, the number of forbidden addresses will be: (1*2^24 + 2^7*2) Why? Because there are two ways of having a forbidden IP addresses: you can either have the netid consist of all 1s or you can have the hostid of either all ones or all zeros. That's why in the first case, I picked the netid 1111111 and then I have 2^24 possibilities for the hostid. In the second case, there can be any netid (total ways of getting one is 2^7), and only 2 host IDs (all 0s or all 1s) and hence, (1*2^24 + 2^27*2) possiblities giving a final result of (2^7 * 2^24) - (1*2^24 + 2^7*2) = 2130706176. However, the answer is: 2130706178. Now, I understand the reasoning given in the book:
Let x be the number of available addresses for computers on the Internet, and let xA, xB, and xC denote the number of Class A, Class B, and Class C addresses available, respectively. By the sum rule, x = xA + xB + xC.
To find xA, note that there are 27 − 1 = 127 Class A netids, recalling that the netid 1111111 is unavailable. For each netid, there are 224 − 2 = 16,777,214 hostids, recalling that the hostids consisting of all 0s and all 1s are unavailable. Consequently, xA = 127 · 16,777,214 = 2,130,706,178.
But I fail to understand where my reasoning is going wrong. I'm getting two less possibilities than the book.
You subtract 0111111 11111111 11111111 11111111 and 0111111 00000000 00000000 00000000 twice as they have both a forbidden netid and forbidden hostid. Your two classes of forbidden addresses are not disjunct.
Likes Phys12
Got it, thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
