How Many Ways Can You Roll Six Dice with Repeating Numbers?
  • Thread starter Thread starter ArcanaNoir
    Dice Probability
64 replies · 7K views
I like Serena said:
No, you allow the 4th die to be the same as the 3rd die here (you didn't before!)
And also for the 5th and 6th die to be the same as one of the other dies.
That's not right.
But vela said it was wrong to say the fourth could NOT the same as the fifth or sixth. :cry:
on Phys.org
That's not right.
Okay I see that for exactly 2 to be the same If I let the last four be whatever they might be more than 2 the same among themselves. so what do I do?
what if I have 2,2,3,3,4,5,6? Is that allowed as "exactly 2 numbers the same"?
I like Serena said:
Ah, I see, vela was using it differently than I was.
Sorry. :blushing:
So now what?
I just realized why vela suggested to start from the other side, but we're not there yet to see why this is the case.
We can continue the way I was going, and show you where things get complex.
But in retrospect I think it's better to first get the solution with as little confusion as possible.
So let's follow vela's pattern of exactly 4 the same and the other 2 as don't care.
That is: XXXX YZ or XXXX YY.
How many possibilities did you have for that?
(6/6)(1/6)(1/6)(1/6)(5/6)(5/6)
ArcanaNoir said:
6!/4! ?
Yes.
However, we still need to distinguish XXXXYZ and XXXXYY.
Do you know how many ways you can shuffle XXXXYY?
The chance on exactly 4 the same would be:
(number of ways to shuffle XXXXYZ) x P(XXXXYZ) + (number of ways to shuffle XXXXYY) x P(XXXXYY).
(6/6)(1/6)(1/6)(1/6)(5/6)(4/6)= 5/1944
(6/6)(1/6)(1/6)(1/6)(5/6)(1/6)=5/7776
[tex]\frac{(6!)(5)}{(4!)(1944)}+\frac{(6!)(5)}{(4!)(2!)(7776)}= \frac{25}{288}[/tex]
Thanks.
Just to be sure,
for exactly 3 the same would it be:
(shuffle XXXYYZ)(PXXXYYZ)+(Shuffle XXXYYY)(PXXXYYY)+(Shuffle XXXYZW)(PXXXYZW)?
(Going out to fix the mailbox with Dad now, don't wait for any more replies from me for a lil while)
ArcanaNoir said:
Thanks.
Just to be sure,
Yep! :smile:
Thanks for telling me so I won't wait unnecessarily for another post. :approve:
Great, thanks for all the help!
I still hate probability. :devil:
In retrospect, we might as well have done the "exactly 2" case, seeing how easily you finished the exercise, once you knew what to do. :wink:
Seeing how easily I finished the exercise, once I knew what to do, I wish you could have just told me what to do in the first place. Maybe I'll remember better since we did it this way, but sometimes PF makes me want to bang my head against the wall!
Any suggestions?
Is there something that might better have been done differently?
I'm still trying to learn as well how to do these things. :shy:
Although I do secretly derive some pleasure of the image seeing you banging your head. o:)
I guess it compensates for the times I was banging my head myself.
Something's wrong. :( When I applied the technique of (shuffle)(Prob)+... to all the dice are different, I got:
(Shuffle abcdef)(Probabcdef)= (6!)(6/6)(5/6)(4/6)(3/6)(2/6)(1/6) = 100/9
Which is clearly not right. What's up?
Ah, yes, I'd forgotten about that. Sorry. :blushing:
Your formula for PEPPER was not complete yet.
It only works because the number of P's is different from the E's and the R.
In your current case you already have all the possible combinations, so the shuffle factor should be "1".
To understand this, look only at the first 2 dice.
The combinations (3,4) and (4,3) are both covered by your calculation.
So there are no extra combinations to be found by shuffling.
The same holds true in the pattern XXXXYZ.
I gave you the wrong number before. Sorry.
The proper formula for XXXXYZ is: 6! / [(4!1!1!)(2!)]
The extra 2! in the denominator is because Y and Z can be exchanged, finding a pattern that you have already counted.
The formula for XXXXYY is still: 6! / (4!2!).
In the case XXXWYZ it is: 6! / [(3!1!1!1!)(3!)]
In the case XXXYYZ it is: 6! / [(3!2!1!)]
In the case XXXYYY it is: 6! / [(3!3!)(2!)], because you can interchange X and Y and find the same pattern.
So the shuffle formula is (number of spaces!)/(number of identical objects! x number of "unique" objects!)?
For example, Shuffle TENNESSEE would be (9!)/(1!4!2!2! x 4!)?
That's not right I think. Can you explain further the shuffling?
TENNESSEE would be (9!)/(1!4!2!2! x 2!)
Since there are two objects (NN and SS) with equal length.
AAABBBCCCDDEEFF would be (15!)/(3!3!3!2!2!2! x 3!3!),
since there are 3 objects of length AAA and 3 objects of length DD.
So.. I still can't get the right answer for "all dice different" using the shuffling. It's supposed to be (720)/(46656)
I did: (shuffle ABCDEF)(P ABCDEF) = [(6!)/(1!1!1!1!1!1!6!)](6/6)(5/6)(4/6)(3/6)(2/6)(1/6) = 5/324
OMG I don't understand how that could have happened. My calculator ALWAYS reduces. Thank you. I'm going to go cry now...
[edit] I know how it happened. This was actually part "a" of the same problem and I wrote it down un-reduced because a number of the solutions in the back of the book are written unreduced. This was yesterday, by today, I forgot I did it that way.
BTW, thank you VERY much for the shuffling explanations, that's going to stick with me a long time, and it wasn't in the book or the notes like that. Just PEPPER. Totally useless to have such a specific example and not even know it shouldn't be generalized without extra information.
I'm afraid the formula is usually not included in course material.
And actually it's pretty hard to write it down properly.
Afterward it's a puzzle again to decipher it.
If you keep it, make sure you also list a lot of examples on how to use it (more than just PEPPER).
And please don't hold your breath before you forget it again. :wink:
I did! :blushing:
I appreciate the thanks. :)
