How much must the spring be compressed? helppp
  • Thread starter Thread starter ohheytai
    Compressed Spring
To launch a 9 kg package from an airless asteroid with a mass of 3.0x10^20 kg and a radius of 2.1x10^5 m, the spring must be compressed to achieve a final speed of 179 m/s. The escape speed calculated is approximately 437 m/s. The total energy required for the launch, considering gravitational and kinetic energy, is 1,707,500 J. The spring's potential energy is given by the formula E = 1/2 kx², where k is the spring constant of 2.3x10^5 N/m. The calculations indicate that the spring must be compressed by about 3.85 meters to achieve the desired launch speed.
ohheytai
how much must the spring be compressed?!? helppp
A package of mass 9 kg sits at the equator of an airless asteroid of mass 3.0x10^20 kg and radius 2.1x 10^5 m. We want to launch the package in such a way that it will never come back, and when it is very far from the asteroid it will be traveling with speed 179 m/s. We have a large and powerful spring whose stiffness is 2.3x10^5 N/m. How much must we compress the spring?
i can't get this someone please help me this is my work
escape speed:
v = sqrt(2GM/R); Where:
G = 6.673 E-11 [m³ / (kg-s²)]; Gravitational Constant
M = 3.0 E+20 kg; Mass of asteroid
R = 2.1 E+5 m; Radius of asteroid
v = sqrt[ 2 * 6.673 E10^(-11) [m³ / (kg-s²)] * 3.0 E10^20 kg ÷ (2.1 E10^5 m) ]
v = 1.9066 E5 m²/s²
v = 437 m/s
E = 1/2 m v²
E = 1/2 (9 kg) (437 m/s + 179 m/s)²
E = 4.5 kg (379496 m²/s²)
E = 1,707,500 J
E = 1/2 kx²
1.708 E6 kg m²/s² = 1/2 (2.3 E5 kg/s²) x²
14.85 m² = x²
x = 3.85m
escape speed:
v = 1.9066 E5 m²/s²
v = 437 m/s
E = 1/2 m v²
Your error starts here. It's incorrect to simply add the escape speed to the final desired speed.
E = 1,707,500 J
E = 1/2 kx²
14.85 m² = x²
x = 3.85m
There are three forms of energy at play here: due to gravity, due to the spring, and kinetic energy. Using that, can you set up an equation from Einitial=Efinal?
