Calculating Power Needed for a Machine's Flight: Tips & Tricks
To calculate the power needed for a machine's flight, it's crucial to understand that the machine's engine output remains at 60 watts despite energy losses due to air resistance. In this case, the machine loses 2.5 * 10^3 Joules to air resistance while gaining potential energy as it ascends to 2230 meters. The total power supplied by the engine accounts for both the energy lost and the energy gained. Therefore, the effective power used for flight remains 60 watts. Understanding these energy dynamics is essential for accurate calculations in flight mechanics.
tennis38
For example, if it takes 60 watts of Power for a machine to fly, yet loses (for instance) 2.5 * 10^3 Joules of its energy because of the air resistance, what's the amount of "Power" that was really given in the first place?
The time of flight for the machine is 30 minutes to get to the height of 2230 meters.
Any suggestions or tips? I've been stumped by this problem for a while now.
Thanks.
It seems that the power is still going to be 60 watts -- even though energy is being lost to air resistance, the engine of the machine is still going to be putting out that much power. So when it flies to a height of 2230 meters, it loses 2.5 * 103 J to air resistance, while also gaining potential energy. Both of these energies will be supplied by the power source.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
