Exploring the Concept of Time: How Much Time Do We Occupy?
  • I
  • Thread starter hlustisa
  • Tags
    Time
In summary: But I think the answer would be a little bit complex and difficult to define.Thank you for the reply!
hlustisa
Hello
If we have this 4D strucuture (being time one of the dimensions) is it right to think that, similarly to the fact the matter ocuppies a portion of three spatial dimensions, it also has a length in time?
If this question makes any sense, would be possible to know how much time we occupy? It would be just a fraction of second, is it more? I mean, the fact we are moving in time torwards what we call the future, doesn't mean that we can't occupy a finite portion of the time dimension at any given "instant".
Another thing I was never able to understand: If matter is able to bend space-time around itself, does it mean that not only space is bent, but also time, right? The time would bent over the space, and as we move in time we also move in space towards the object that causes time to bent. In this case, the same way Earth's gravity acts all around it (in space) , it alsos acts in time? Does the Earth from this exact instant in time generate a gravitational field that can be felt back in time, or even in the future? Could we measure it? Does the gravitational field we experience now is the result from the sum of gravity generated by many Earth's on different time instants?
Forgive me if it is all BS, but those are honest questions from a non physicist.
The question does not make sense. A moment is by definition not extended in time. An object will define a four-dimensional region of space-time (world volume), but this is due to the object existing at different moments. As a similar question, consider the following:
What is the extent in the x-direction of the circle x^2 + y^2 < 1 at x = 0.5? Since you are asking about x = 0.5, the object you are going to look at has no extension in the x-direction. The circle itself is extended in the x-direction, but this is more related to an object actually defining a world volume than having an extension in time at a fixed moment (which, as stated, does not make sense).
Ok. I got it. It depends on how I define the object. I could define it as having 0 length in time, which means is a "different" object at any given instant, or as a 4D object considering it exists in different instants.
We tend to look at objects and measure their volume. Take a look at a ball for instance, we perceive how much space it occupies because It has a boundary (it is arbitrarily defined, but its a boundary), The particles that make up the ball are connected or related to each other in such manner that we think about it as a unity. In this context, my question was about perceiving this same unity in time. During a finite amount time, that ball is a unity, and then it is not tight together anymore, or not bounded to its previous version so strongly that it becomes another object entirely.
Thank you for your answer.
Do you have any coments about the last question?
Hi hlustisa, welcome to PF,
If we are lucky we occupy 70 or 80 light years of time. In spacetime we are much longer in the time dimension than in any of the spatial dimensions.
hahahaha =]
This is actually the point. If I ask you where your body ends and the environment around you begins, you can easily answer me.
But in time, do you really think you are exact the same "object" from cradle to grave? Is there a "natural" range in time in which you get so decoupled from your previous versions that you become something else?
I am asking this because of my other question, related to effect of the gravity in time. I wonder if there is a time range in which we fell the effect of future's Earth gravity or something like that.
This is a more philosophical than physical question. You can draw the boundaries of a system under study as you wish as long as you specify how that system interacts with its surroundings.
This sounds like something taken from reading popular science and trying to think like it. It does not have any physical coherence and is not very well defined. Also be advised that the discussion of personal theories is not allowed at Physics Forums.
A very short time at bigbang time may be long here,, Wich is good, I suppose.I didn`t understand the question.
Orodruin said:
This is a more philosophical than physical question. You can draw the boundaries of a system under study as you wish as long as you specify how that system interacts with its surroundings.This sounds like something taken from reading popular science and trying to think like it. It does not have any physical coherence and is not very well defined. Also be advised that the discussion of personal theories is not allowed at Physics Forums.
I am sorry. I did not realize this could be qualified like that. I don't mean to go against the rules of the community. I could not find a way to delete the thread.
hlustisa said:
hahahaha =]
Uhh, that wasn't a joke. I was answering the question. In spacetime an object is as long in time as its "lifetime" times c. So for a human that is 70-80 light years long.
That is a philosophical question, but I don't think that the answer is important. Whatever events you choose as defining the beginning and the end of the "object", the corresponding length in the time direction in spacetime is that duration times c. I would choose birth and death for a human, with a corresponding 70-80 light year length, but if you wanted to choose different events then you could certainly do so. The science part is clear, only the philosophy is vague.
It's ok, that was just a friendly reminder. We can close the thread on that note, though.
1. How do scientists calculate how much time we occupy?
Scientists use various methods to calculate how much time we occupy. One common method is to track our daily activities, such as sleeping, eating, and working, and then estimate the total amount of time we spend doing these activities over a certain period of time. Another method is to analyze data from surveys or studies that ask individuals to report how they spend their time.
2. Is there a difference in how much time we occupy compared to previous generations?
Yes, there is a difference in how much time we occupy compared to previous generations. With advancements in technology and changes in societal norms, our daily routines and activities have shifted. For example, people today may spend more time on their phones or computers compared to previous generations who did not have these technologies.
3. Do certain factors, such as age or occupation, affect how much time we occupy?
Yes, certain factors can affect how much time we occupy. Age can play a role, as younger individuals may have different daily routines and activities compared to older individuals. Occupation can also impact how much time we occupy, as different jobs may require different amounts of time and effort.
4. How does the amount of time we occupy impact our health?
The amount of time we occupy can have both positive and negative impacts on our health. Engaging in physical activity and getting enough sleep are important for maintaining good health, while spending excessive amounts of time sitting or being sedentary can increase the risk of health issues such as obesity and heart disease.
5. Can we change how much time we occupy?
Yes, we can change how much time we occupy by making conscious choices about our daily routines and activities. By prioritizing activities that are beneficial for our health, such as exercise and quality sleep, we can increase the amount of time we spend on these activities and decrease the time we spend on activities that may be detrimental to our health.
