How much total kinetic energy is needed in this case?
eri3an
I have a problem with an exercise from school. could anyone help me?
Let say that you are searching for a new particel X by making collison between positrones and elektrones in an particelaccelerator. you guess that the new particles resting mass is 210 MeV/c^2 and you hope to produce it by:
(e+) + (e–) ---> X + photons
a) Let us say that the electron (e-) is in resting state in the laboratory system. How much energy is needed to accerate positrons (e+) to such a velocity for the reaction to take place?
b)On less energy demanding way of doing it is to let e+ och e– collide with each other from opposite directions with the same velocity How much total kinetic energy is needed in this case?
resting mass for an electrone or positron is 0.511 MeV/c^2
please I'm not interested in just getting an answer how do i solve it? I've tried by deriving from the E(a) + E(b) = E(c) + E(d) and tried to go using conservation of momentum but it doesn't seem to work :( Maybe I'm out on bad ice?
Hi eri3an,
you must remember Einstein's equation : E = mc^2, where m is the mass of the particle when it is moving.
I suggest you to study the problem in the CM (centre of mass) system.
Then you can pass to the system of the laboratory by Lorentz transformations.
borisleprof said:
Hi eri3an,
i just though this statement could use some elaboration:
E=\gamma m_0c^2=\sqrt{m_0^2c^4+p^2c^2}
i think using the real mass, i mean the thing you divide the force with to get the accelaration is better (and that's what borisleprof did).
but in most textbooks, they talk about the mass you measure at the rest frame...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
