How much work done by a ball during an oblique collision?
In an oblique collision, the work done on the surface by a ball primarily involves the kinetic energy associated with the normal velocity, while tangential motion can be ignored if friction is absent. Kinetic energy, though a scalar, can be analyzed through its components in different directions using the Pythagorean theorem. The work done on a stationary wall is technically zero since no distance is moved, but if the wall deforms, the analysis becomes more complex. The impulse applied during the collision can be calculated using changes in momentum, and the relationship between force, time, and distance is crucial for understanding work done. Overall, the specifics of the collision, including wall movement or deformation, significantly influence the energy transfer dynamics.
sfensphan
Suppose I have a ball colliding with a surface at an oblique angle. I want to know what work will be done on the surface. Now, there is kinetic energy associated with the tangential and normal velocity of the ball. Can I say that the kinetic energy of the ball associated with the normal velocity is the only energy that does work on the surface? That makes sense to me, but I read that kinetic energy is a scalar, so can't be split up. I'm assuming that there is no friction. Any thoughts would be much appreciated.
Kinetic energy, like speed, can be increased or decreased. When the ball hits the wall, part of its energy is used to heat the wall and the ball up, assuming it just bounces off the wall. The ball has lost energy in this interaction and given it to the particles in the wall (heat energy or molecular kinetic energy). Finding out exactly how much energy you need to know the angle, speed, composition of the ball and wall, and many more values. If you know speed before, speed after, and ball weight you can loosely determine the amount of energy lost.
Since you are assuming no friction, it follows that there can be no component of the collision force that is parallel to the wall. The force must all be in the perpendicular direction. You are correct that this means that any motion of the ball parallel to the wall can be ignored in computing work done.
Although kinetic energy is a scalar, that does not mean that we cannot account for the total kinetic energy as partly due to motion in the x direction, partly due to motion in the y direction and partly due to motion in the z direction. The pythagorean theorem makes this work out nicely. We know that the square of total velocity is the sum of the squares of the velocity components in the x, y and z directions. So total energy is given by one half of mass times the sum of the squared velocity components in the x, y and z direction.
However, that's largely irrelevant to the question you posed. Recall the definition of work as the [vector dot] product of force applied multiplied by distance moved. If the wall is not moving that means that no work is done on the wall.
If the wall is moving then, in the absence of friction, the work done can be computed as distance moved by the wall (in the normal direction) multiplied by force applied by the ball (which is neccessarily in the normal direction).
We normally treat a collision as if it were instantaneous. So the force applied is infinite and the duration is zero. That means that the product of force applied times distance moved is technically undefined. However, it turns out that one can still solve such problems. The product of force applied times duration of collision is equal to the "impulse" applied to the ball. If you know how much the momentum of the ball changed then that is how much impulse was involved.
impulse(ball) = m(ball) * delta-v(ball)
By Newton's third law, the impulse applied to the wall is equal and opposite.
impulse(wall) = - m(ball) * delta-v(ball)
Recall the definition of impulse as force multiplied by time.
force-on-wall * collision-duration = - m(ball) * delta-v(ball).
Multiply both sides by the velocity of the wall
force-on-wall * collision-duration * velocity(wall) = -m (ball) * delta-v(ball) * velocity(wall)
But time times velocity gives a distance
force-on-wall * distance-moved-by-wall = - m(ball) * delta-v(ball) * velocity(wall)
And that's what we're after
work-done-on-wall = - m(ball) * delta-v(ball) * velocity(wall)
[There is some lack of rigor in the above, but it can be worked out rigorously and still gives the same result]
Thanks for the very detailed reply! I suspected that they would be separable (if that's the right word) for the case in which the wall is rigid but just didn't know what tool to use.
A followup if I could. What if the wall doesn't move but deforms? I don't think it would be as separable as before. Thanks again for your thoughts!
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
