How much work is done by friction during the car's slide down the hill?
In summary, a 320 kg car sliding down a hillside that is 500 m long and 300 m high with a coefficient of kinetic friction of 0.23 will have a gravitational potential energy of 940800 J before the slide and will lose 601067 J of mechanical energy due to frictional forces during the slide. To calculate the work done by friction, the correct value of cosθ must be used in the formula μmg*cosθ.
fatty1
A 320 kg car slides from rest down a hillside that is 500 m long and 300 m high. The coefficient of kinetic friction between the car and the hill surface is 0.23.
1) If the gravitational potential energy PE of the car-Earth system is set to zero at the bottom of the hill, what is the value of PE just before the slide?
2) How much mechanical energy is wasted by frictional forces during the slide?
PE = mgh
Frictional force = (kinetic friction) * (mg cos theta)
Work = Final Energy - Initial Energy
I tried to solve the first question with the potential energy equation but I am having trouble solving the second equation.
I assume you can treat the hillside as if it were a straight incline.
What's the force of friction? You have the formula. What's the angle of the incline?
Use that friction force to calculate the work done by friction.
I did it this way.
1) PE = mgh = 320 x 9.8 x 300 = 940800 J
2) By work energy theorem:
=>W = Delta Energy
=>Delta Energy = kinetic friction * distance
=>Delta Energy = 0.23 * 320 * 9.8 * [300/500] * 500
=>Delta Energy = 216384 J
I did it this way, but for question 2, should the answer be negative since it loses energy?
fatty1 said:
I did it this way.
Perfectly correct.
=>W = Delta Energy
You're using the definition of work-- work=force*displacement--not the work-energy theorem. You've made an error: 300/500 is the sine of the angle, not the cosine.
The work done by friction is negative, since the force and the displacement are in opposite directions. But the amount of energy 'wasted' would be positive.
potential energy just before the slide(at top of hill)= mgh= 320*10*300
let me give you some help with the second question. If the energy were not to be lost then the whole of the potential energy would have converted into kinetic energy and velocity at the bottom would have been v=sqrt(2gh) .but in this case the velocity will be less than this calculated velocity and this is where the energy is lost.
So at first calculate the acceleration down the hill of the car.
ma= mgsinA -(Coeff of friction, U)*mgcosA , I am using A in place of theta
a=4.16 m/s^2 if you put g=10m/s^2
Now velocity at the bottom is given by
v^2=2*a*S(hypotenuse distance of the hill)
v=64.5 m/s
therefore K.E at bottom =665600 J
Loss is energy = P.E at top - K.E at bottom
=>W = Delta Energy
=>Delta Energy = 0.23 * 320 * 9.8 * [500/300] * 500
=>Delta Energy = 601067 J
I reversed that and got this value. If it is not correct, then can you explain much clearer about the work energy theorem?
fatty1 said:
2)
=>W = Delta Energy
Again, this is not the work-energy theorem. You are just using the definition of work.
You still made an error in calculating the friction force, which should be μmg*cosθ. Before you had sinθ, instead of cosθ; now you have 1/sinθ, which is still not correct. Hint: In the right triangle formed by the hill, the hypotenuse is 500, the side opposite the angle is 300, so what's the third side?
FYI, the work-energy theorem states that the net work done on a body will equal its change in energy. We don't need to use that here. You could use it, but doing it the way you are attempting to do it is better and quicker. You just need to get the correct value for cosθ. :wink:
Related to How much work is done by friction during the car's slide down the hill?
1. What is potential energy?
Potential energy is the energy that an object possesses due to its position or state. It is the energy that is stored within an object and has the potential to do work when it is released.
2. How is potential energy different from kinetic energy?
Potential energy is the energy that an object has due to its position, while kinetic energy is the energy an object has due to its motion. Potential energy is stored energy, while kinetic energy is energy in motion.
3. What are some examples of potential energy?
Some examples of potential energy include a stretched rubber band, a compressed spring, a raised object, and chemical energy in food or batteries. The amount of potential energy an object has depends on its position and the forces acting on it.
4. How is potential energy calculated?
The formula for calculating potential energy is PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height or distance from the ground. The unit for potential energy is Joules (J).
5. How is potential energy used in real life?
Potential energy is used in various ways in our daily lives. For example, potential energy in food is converted to kinetic energy to power our bodies. Potential energy stored in batteries is converted to electrical energy to power devices. In nature, potential energy in water is harnessed to generate hydroelectric power. It is also used in roller coasters, springs, and many other applications.
16K
