How Much Work is Required to Stretch a Series of Strings?
To calculate the work required to stretch a series of springs from their equilibrium position, the formula W = (1/2)kx^2 is used. The value of k for two springs in series can be determined using the equation k = 1/(1/k1 + 1/k2). This approach allows for the correct calculation of the total spring constant for the system. Once k is established, the work done can be accurately computed. The discussion confirms the method for finding k is correct.
BraedenP
Given the constants k_1 and k_2 and distance x, determine how much work is required to stretch the spring x from equilibrium position.
W=\frac{1}{2}kx^2
All I need to determine is what my value is going to be for k. Am I right in calculating that k for the entire system of two springs will be \frac{1}{\frac{1}{k_1}+\frac{1}{k_2}}?
If so, then I should be able to answer my question.
Yes that would be correct.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
9K
