How short a distance to come to a stop without sliding?
  • Thread starter Thread starter rachie9
    Short Sliding
To determine how short a distance a railroad car can stop without sliding crates, the static friction coefficient of 0.5 is used to calculate the maximum deceleration, which is 4.9 m/s². The net force is zero to prevent sliding, and the relationship between acceleration and gravity is crucial. The discussion emphasizes using kinematic equations to relate initial velocity, acceleration, and distance. Sketching the scenario can help visualize the problem and identify relevant equations. Ultimately, the focus is on applying these principles to find the stopping distance effectively.
rachie9
A railroad car has crates in it with a coefficient of .5 w/ the car's floor. The train is moving at 22m/s, how short a distance can it be stopped w/o letting the crates slide?
Fnet = 0 because you don't want sliding.
a = coefficient of static friction x gravity
When I solved for a, I got 4.9m/s2. I know if I multiply this by the mass of the crates, it should be equal to the static friction force.
I think I have to take the derivative of the velocity to get acceleration, and the antiderivative of velocity to get distance, but how do I do this with no other variables?
I've not checked the working for the earlier part of the question.
Draw sketches of the train at the start and the end of the problem, write on all the values you know, and see what equations you might be able to use. (Think kinematics.)
You have the initial velocity and the acceleration. You can find distance traveled from that information.
