How Thick Should Carbon Fiber Springs Be to Withstand a 200-Pound Impact?
To design carbon fiber springs that can withstand a 200-pound impact while deflecting only 2-2.5 inches, it's essential to consider both dynamic and static response factors. Calculating the required thickness involves analyzing the kinetic energy of the falling weight and the spring's static position. Additionally, damping is crucial; without it, the spring could rebound the weight after impact. The discussion highlights the complexity of spring design under dynamic loads. Proper calculations and damping mechanisms are necessary for effective performance.
TORE BACK
Hello this is me first post on here i don't know if this would be the right section but I'm trying to design and build this spring to only deflect 2-2.5 inches the force on it will be 200 pounds falling from 6 feet and coming down on the the two circles. my problem is i need to learn how to calculate what thickness it should be because i have to build a few that will range from 120 to 220 pounds falling from the same height
Any help would be appreciated
Thank you
Tim Russo
anyone
This is a difficult problem to answer, you'll have to take both the dynamic and static response factors of the beam into account. The analysis will involve looking at the kinetic energy of the falling body, as well as the static position of the body on the spring.
What you haven't mentioned though is how you plan to damp this system, since if the body falls onto the spring and the spring absorbs all of the energy, then in turn it will bounce the body back up. It's a classic undamped spring/mass problem from physics.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
