How to calculate bonding strength of an adhesive tape
  • Thread starter Thread starter Shady99
    Bonding Strength
The discussion revolves around calculating the bonding strength of adhesive tape, specifically in the context of adhering a 10 kg aluminum block to a steel wall using double-sided tape. Participants explore the mathematical approaches and considerations involved in determining the bonding force between the tape and both the wall and the block.
  • One participant inquires about the method to calculate the bond strength of adhesive tape for a specific application involving an aluminum block and a steel wall.
  • Another participant suggests checking the datasheet for the tape, noting the importance of the operating temperature range and sharing a personal experience with tape limitations in electronics applications.
  • A participant expresses a desire to understand the mathematical calculations involved, indicating uncertainty about the simplicity of such an approach due to variability in adhesive formulations.
  • There is a reference to the "Typical Performance Characteristics" section of the datasheet as a potential source of information regarding bonding strength.
  • A participant questions how to determine if the block will adhere or fall based on the tensile strength of the tape, which is stated to be 40 kPa.
  • One participant suggests starting with a free body diagram as a possible method to analyze the problem.
Participants express varying levels of uncertainty regarding the mathematical approach to calculating bonding strength. While some suggest referring to the datasheet for specific values, others highlight the complexity and variability of adhesive properties, indicating that no consensus on a straightforward calculation method exists.
Limitations include the variability of adhesive yield strength across different formulations and the dependence on specific conditions outlined in the datasheet. The discussion does not resolve the mathematical steps necessary for calculating bonding strength.
Shady99
Hello i would like to know how to find out the bond strength of the adhesive tape. The problem is i have a aluminum block of 10 kgs. I want to stick the block on a steel wall with double tape. Now how can i calculate the bonding force of the bond between the1) tape and wall 2)tape and block
Is that not in the datasheet for the tape?
BTW, be sure to check the operating temperature range of the 2-sided tape. I recently almost made a giant error using standard 3M 2-sided sticky tape for an electronics application. The standard tape is only good for something like 10C to 50C. I did finally find some wide temperature range 2-sided tape (3M VHB)...
Actually i was wanting to know the maths for how to do calculations for such a problem
I'm not sure there is a simple mathematical approach. The yield strength of the adhesive varies so much from formulation-to-formulation... Is there anything on the datasheet about the bonding strength? I can go check the datasheet for the VHB tape I'm using now...
See the section on "Typical Performance Characteristics" mid-way down the datasheet:
https://multimedia.3m.com/mws/media/67100O/3mtm-vhb-tapes.pdf
Say the tensile strength of my tape is 40 kpa...how to know if the block will stick onto or fall?
Perhaps start with a free body diagram.
