How to calculate complex dot products
  • Thread starter Thread starter BOYLANATOR
    Complex Dot
BOYLANATOR
let y1=(1,0,i,0) and y2=(0,i,1,0)
what is (y1.y2)/(y1.y1)?
I make it i/(1+i2) = i/0 which seems incorrect.
My notes seem to give the answer as -i/2 and I don't understand how this was calculated.
Any help is appreciated. Thanks
hmm.. I get (i/0) as well.
(1*0 + 0*i + i*1 + 0²) / (1² + 0² + i² + 0² ) =
(0 + 0 + i + 0 ) / (1 + 0 -1 +0) =
(y1*y2)/(y1²)= i/0
Does anyone get a different answer?
I suspect the answer is to do with the fact that
<z1,z2>=<(z2)*,z1> where (z2)* is the Hermitian conjugate of z2, but even if this is the case I'm not sure how to carry out the calculation.
It seems to work with y1 = (i,0,i,0), you probably didn't copy it correctly.
The usual (euclidean) complex dot product in \mathbb C^n is defined as the sum of the
products of the first vector's coordinates times the conjugate of second vector's coordinates.
In your case, y_1\cdot y_1 = 1\cdot 1 + 0 + i\cdot (-i) +0=2 , and this is what must appear in the denominator.
DonAntonio
Thank you DonAntonio
I must have missed this definition. When you apply it to the numerator as well, you get the correct answer -i.
Thanks
Thanks
No. It is either y_1\cdot y_2 = i\,\,or\,\,y_2\cdot y_1=-i. Check this.
DonAntonio
Yes it was y[2].y[1] = -i . From the Gram-Schmidt Process although I changed the notation slightly.
Thanks
