How to calculate in a nested supermesh?
  • Thread starter Thread starter hpare
To calculate currents in nested supermeshes with two current sources, it's essential to use matrix math. Posting the schematic of the network is crucial for providing specific guidance. Without the schematic, only general advice can be offered. The discussion emphasizes the importance of visualizing the circuit for accurate calculations. Clear instructions and a visual aid will lead to a more effective solution.
hpare
There are two current sources forming two supermeshes and I don't know how to calculate each current for each mesh in the supermeshes.
Do it with matrix math.
Post the schematic of the network you're trying to solve. Otherwise, only general advice can be given.
Welcome to the PF. Is this for schoolwork?
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
