How to calculate kinematic distances in the Milky Way
  • Context: Undergrad
  • Thread starter Thread starter Ben231111
    Kinematic Milky way
This discussion focuses on calculating kinematic distances to the spiral arms of the Milky Way using the tangent point method. The equation employed is R = (Vsun*Rsun*sin(l))/(Vobs+Vsun*sin(l)), where Vsun is the Sun's velocity and Rsun is the distance from the Sun to the galactic center. The user reports successful calculations for longitudes between 0 and 90 degrees but encounters inaccuracies for longitudes between 90 and 270 degrees. The issue appears to stem from the definition of Vobs, which may not account for negative velocities when clouds are moving towards the observer.
  • Understanding of kinematic distance calculations in astrophysics
  • Familiarity with the tangent point method for distance measurement
  • Knowledge of the Doppler Effect and its application in astronomy
  • Basic grasp of galactic coordinates and their significance
  • Research the implications of negative velocities in kinematic distance calculations
  • Explore alternative methods for calculating distances in the outer galaxy
  • Study the effects of galactic rotation on observed velocities
  • Investigate the use of 3D modeling in galactic distance measurements
Astronomers, astrophysicists, and students studying galactic dynamics or kinematic distance measurements in the Milky Way.
Ben231111
I have been trying to calculate the distances to the spiral arms (neutral Hydrogen clouds) and our equation seems to work perfectly for longitudes 0<l<90 but doesn't seem to work for the outer galaxy (i.e. between 90<l<270) - we get distances but they're not correct. After reading a lot of literature online it seems the outer distances should actually be easier to calculate given that there would only be one solution, rather than two like in the inner galaxy.
I'm using the tangent point method and the equation I am using to calculate the distance from the centre of the galaxy to the cloud is R = (Vsun*Rsun*sin(l))/(Vobs+Vsun*sin(l)) where Vsun is the velocity of the sun, Rsun is the distance from the Sun to the galactic centre.
Vobs is calculated from the Doppler Effect using Vobs = c*(1-f'/1420.405...) - vlsr where c is the speed of light, f' is the observed frequency and 1420.405... is the frequency of the Hydrogen emission.
I then use my R and calculate the distance d from the Sun to the cloud using d = Rsun*cos(l)±√((Rsun*cos(l))^2 - Rsun^2 + R^2)
As said before, this all seems to work fine for 0<l<90, but not for l>90. The only thought I have had is that the way I have defined Vobs (defined as the velocity of the cloud along the line of sight minus the velocity of the Sun along the line of sight) might be true for all l<90, but not necessarily true for l>90 - for some longitudes and distances (i.e between 90<l<270), Vobs may become negative as the cloud is now moving towards us, instead of away.
Any help with this is appreciated, thanks!
Astronomy news on Phys.org
Any help?
Thanks
  • · Replies 16 ·
14K
