How to calculate net Thrust of rocket
  • Thread starter Thread starter deeppurple247
    Net Rocket Thrust
The discussion focuses on calculating the net thrust of a rocket, factoring in gravitational force. The rocket reaches an escape velocity of 11,200 m/s in 5 minutes, resulting in an acceleration of 37.3 m/s². The mass loss rate of fuel is determined using the equation q = ma / v, yielding a rate of 770 kg/s. The thrust is calculated as T = qv, resulting in a thrust of 1,925,000 N. However, the total force due to gravity exceeds this thrust, indicating a potential error in the calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with rocket propulsion principles
  • Knowledge of fluid dynamics, specifically pressure and density calculations
  • Proficiency in using differential equations for motion analysis
  • Study the principles of rocket propulsion and thrust calculation
  • Learn about the integration of differential equations in motion analysis
  • Research the effects of drag force on rocket performance
  • Explore methods for calculating mass loss rates in rocket fuel consumption
Aerospace engineers, physics students, and anyone involved in rocket design and performance analysis will benefit from this discussion.
deeppurple247
Trying to calculate the net thrust of a rocket taking into account the force due to gravity. So I presume this is the calculated Thrust minus the force due to gravity.
Known data so far is that the rocket gets to escape velocity (11,200 m/s) after 5 minutes (300 secs). Acceleration for this is 11,200 / 300 = 37.3 m/s/s.
Next needed to calculate the mass loss rate of fuel. Equation given for this was was q = ma / v where q is the mass loss rate, m = final mass of rocket, a = acceleration and v = fuel exit.
m was given as 50,000 kg + 2000 Kg = 52,000 kg (without fuel)
v was calculated from equation earlier with sqrt((2 * (P2 - P1))/p), with given pressures and density. This came out as 2500 m/s
So...
q = (52,000 * 37) / 2500 = 770 kg/s
From this the Thrust (T) = qv = (770 * 2500) = 1,925,000 N (It was assumed the pressures were the same so T = qv)
Calculating the total mass of the rocket on launchpad needs the weight of the fuel which I presume is the mass loss rate (770 Kg/s) multiplied by the duration of fuel (300 secs) = 231,000 Kg
Therefore the force due to gravity is...
F = ma = (231,000 + 52,000) * 9.8 = 2,773,400 N.
This is more than the thrust calculated earlier which would give a negative net thrust which cannot be correct. Can anyone see where I've gone wrong please?
Regards
http://arxiv.org/ftp/arxiv/papers/0903/0903.1555.pdf
The attached paper gives a method that should work. I think you will need to assume constant thrust, and used the guess and check method of integrating the differential equation until you get the given velocity at the given time, because the drag force is changing with velocity.
Thanks for quick response. One thing I forgot to mention also is that force due to drag is ignored.
  • · Replies 42 ·
