How to calculate position and velocity?
To calculate position and velocity at t=3 seconds, use the equation of motion for uniform acceleration, which is derived from F=ma. Given a force of 1 N and a mass of 1 kg, the acceleration (a) is 1 m/s². The position can be calculated using the formula: position = initial position + initial velocity * time + 0.5 * acceleration * time². For this scenario, the initial position is -2, and the initial velocity is 0, leading to a calculated position of 2.5 at t=3 seconds. This aligns with the simulation results, confirming the calculations are consistent.
pill
I used an online simulation for this lab.
Mass: 1.0 kg
Force: 1 N
X position: – 2
Y position: 0
The final position was 6.0, final velocity was 4.0, and final time was 4.0
At 3 seconds the position was at 2.50 and velocity was at 3.00
Because I used an online simulation I already know what the position and velocity was when t=3. However, my lab is asking me, "How does this compare with the calculated position/velocity at t = 3?" What calculation do I need to use to calculate position and velocity at t=3? Just the equation will do. An explanation of the equation would be better, but I will take what I can get.
Assuming that this is a horizontal surface that the object is traveling across, I believe the equation you are looking for is F=ma. With a few extra calculations using acceleration, you should get a position at t=3.
So for this equation a=1 (1=1a, 1/1=a, 1=a). What equation(s) would I use after this?
equation of uniform acceleration
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
