How to calculate pressure from steam
  • Context: Undergrad
  • Thread starter Thread starter 01SpAcE01
    Pressure Steam
The discussion revolves around calculating the pressure inside a cylindrical pressure vessel containing water heated to 130 degrees Celsius. Participants explore the concepts of circumferential pressure, hoop stress, and the state of steam (saturated vs. superheated) in the context of this scenario. The conversation includes technical reasoning and clarifications related to pressure calculations and the properties of steam.
  • One participant seeks to calculate the circumferential pressure in a pressure vessel with specific dimensions and water volume.
  • Another participant questions whether the inquiry is a homework problem, indicating a potential academic context.
  • Some participants suggest using steam tables to determine the properties of steam at the given temperature and volume.
  • There is a discussion about whether the steam produced is saturated or superheated, with differing opinions on the conditions required for each state.
  • Clarifications are requested regarding the term "circumferential pressure," with some suggesting it may refer to "circumferential stress" and emphasizing the need for wall thickness information.
  • Participants mention the ideal gas law to account for the contribution of air pressure in the vessel.
  • There is a suggestion that the problem can be approached using online resources and calculators, though some express frustration over the perceived lack of independent research by the original poster.
  • One participant emphasizes the importance of showing work and calculations to progress in solving the problem.
Participants express differing views on whether the steam is saturated or superheated, and there is no consensus on the best approach to calculate the pressure and stress in the vessel. The discussion remains unresolved with multiple competing perspectives on the topic.
Participants note the importance of considering the initial conditions of air in the container and the assumptions regarding the volume of liquid water and its behavior upon heating. There are also concerns raised about safety in conducting experiments related to pressure vessels.
This discussion may be of interest to individuals involved in engineering design, thermodynamics, or those studying pressure vessel design and steam properties.
01SpAcE01
So let's say we have a cylindrical pressure vessel of volume 2.4 x 10^-3 m^3 carrying 2 liters of water heated to 130 degrees Celsius, how would I calculate the circumferential pressure inside the container?
radius = 56x10^-3 m
height = 0.24 m
I know the equation would be stress=pressure x radius / thickness. Just never had to calculate the pressure before.
Also, if someone is feeling extra nice, would you mind clrifying this for me please: If steam is created in an environment that has 2 liters of water, but then the element further heats the water to 130 degrees Celsius, then would this create saturated steam or superheated? I always thought superheated, as the vapour must exceed 100 at some point if it is in a sealed environment. I just read something today that confused me somewhat.
radius = 56x10^-3 m
height = 0.24 m
Is this a homework problem?
You could say it is. I'm at home and working. Not a student though. Trying to design something and refresh my engineering skills.
Google online steam tables. You can look up the answer there. As long as the volume of the container is bigger than the initial volume of water, it will not influence the answer.
As long as you have both liquid and vapor in the tank, the vapor will be saturated, and you can look up the properties of saturated steam. Is there also air in the container? If yes, it will affect the answer.
I certainly hope that you are not trying this as a home experiment. Boiler explosions are deadly. We do not discuss dangerous topics on PF.
Absolutely not something I would experiment with at home :) I've another year of design and research before I have some prototype to test, but that would be done in a controlled environment and with professionals.
There will be air in the container, then 2 liters will enter, seal, and then heat to 130 degrees.
Would you mind giving me an online link. I'm a bit confused as to what to do...
Also, please tell us your understanding of the term circumferential pressure. Do you really mean "circumferential stress?" If this is what you want, then you also need to know the wall thickness of the tank.
If there is air in the tank to start with, then you need to use the ideal gas law to include its contribution to the total pressure.
Chet
Chet
The hoop stress is what I mean. Firstly I need to understand the uniform force created by this circumstance I guess. Isn't there some simple calculator online?
I don't mean to sound rude here, but you are asking some questions you could be googling. The equation for hoop stress is pretty straightforward, so I'd just use that...but does an online calculator exist? I don't know: I could Google that for you...
Sorry but you are being a bit rude. I've already stated the hoop stress equation above. Coming at something from a fresh angle can be a bit too broad and makes you unsure what you should be looking at.
I don't think Russ was being rude. What he was referring to was that there are two separate parts to this problem:
  • Determining the final pressure at 130 C
  • Determining the hoop stress
Russ was saying that the equation for determining the hoop stress from the pressure is readily available on the internet. Also available on the internet is the equilibrium vapor pressure of water vapor in equilibrium with liquid water at the each temperature. Also, if you assume that the starting pressure of the air is 1 atm, and you assume that the volume of liquid water does not change significantly when the temperature goes to 130 (and some of it vaporizes into the heat space), then you can calculate the new pressure of the air using the ideal gas law. So, you have everything you need to solve your problem.
PF rules are that we don't solve the problem for you. So please start using the info we have provided and show us your progress. If you still can't solve it with the information we have provided, you need to hire a consultant.
Chet
Okay, let's see your work. Equations and calculations. Which is it going to be...
10K
  • · Replies 23 ·
  • · Replies 43 ·
14K
24K
