How to Calculate the Electric Field Between Two Different Shaped Electrodes?
The discussion revolves around calculating the electric field between two electrodes: one square and one circular. The dimensions and potentials of the electrodes are provided, with the square electrode positioned inside the circular one. Participants are exploring the application of Laplace's equation and the implications of boundary conditions in this context.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the potential use of Laplace's equation and the necessity of boundary conditions. There are questions about the dimensionality and applicability of certain equations, as well as the need to integrate over charges on the surfaces of the electrodes. Some participants express uncertainty about the uniqueness of the solution and the behavior of the electric field within the electrodes.
The discussion is ongoing, with various interpretations and approaches being explored. Some participants have offered insights into the mathematical framework, while others are questioning the assumptions made about the electric field within the electrodes. There is no explicit consensus yet, but the conversation is productive with multiple perspectives being considered.
Participants are considering the problem in the context of numerical methods, specifically mentioning the finite difference method for solving Laplace's equations. There are references to the need for a grid for computations and discussions about the appropriate units for the results.
Shot
Calculate electric field between two electrodes — one square and one circular. Dimesions of the electrodes are given (diameter a and length of the square side b) as well as their potentials. The square electrode is placed inside the circular one.
[tex]F = k\frac{Qq}{r^2}[/tex]
[tex]E = \frac{F}{q}[/tex]
[tex]V = \frac{E}{q}[/tex]
I'm new to this forum and I'm not a physics guru (last time when I had touch with Physics was 3 years ago). Now I have to solve one problem in SciLab, but I can't figure out where to start. I'm asking for some help - some hints where I could start or some sketch solutions how to do this.
After the research I think I should solve two Laplace equations (in polar and cartesian coordinates) and then sum the results, but I am not sure about that. Also, I know that I need a grid N x N (where N = e.g. 60) to have nice computations.
Hello Shot, and welcome to PF.
Your 1 and 2 equations I understand. 3 is a mystery to me, also dimension-wise. You sure ?
Anyway, they apply to charges and can be used for charge distributions. Not what you have at hand here.
Your hunch that you are expected to solve Laplace equation is much more appealing. What boundary conditions do you think have to be imposed ?
If you are lucky, the exercise wants the circular electrode in the center of the square (you don't mention that!) and you can use symmetry.
What exactly are nice computations ? Are you asked to do this numerically or analytically ?
(PS can't help you further until next wednesday, so hopefully others jump in...)
In principle you could use the first two equations, but you would have to sum/integrate over the charges(Q) on the surfaces of the electrodes, thus having to solve for these charges using more equations.
In the third equation E is the electric potential energy, not the electric field. The relation between V and E is ##E=-\nabla V##
Only way I see is solving Laplace's equation with the obvious boundary conditions.
Can't imagine a closed-form solution. A job for finite-element analysis software!
The first two equations give a relation between the eletric field and the charges. Gauss's law ##\nabla \cdot E = \frac{\rho}{\epsilon_0}## gives this in a more usefull way here.
I was thinking about something like: the Q's must be such that E = 0 inside the electrodes and normal to the surfaces and produce the given potentials on the surfaces. I would say there is only one solution, but I'm not absolutely sure.
Yes awful!
Yes awful!
Why is E=0 inside the electrodes? I see the E field as zero only at the center, assuming the electrodes are concentric.
I believe the Uniqueness Theorem guarantees that there is only one solution.
I assumed they were conductors. (If E is non null, charges would move until E = 0 inside)
For dielectrics hem...
Thanks for the theorem.
Oh, sorry. Of course. I thought you meant inside the circle and square.
I've googled some knowledge about FDM method for solving Laplace equations (since I have to solve this problem numerically using SciLab) and for rectangular rod I've obtained the following equation (in Cartesian coordinates):
[tex] T_{i+1,j} + T_{i-1,j} + T_{i,j+1} + T_{i,j-1} + 4T_{i,j} = 0[/tex] (assuming Δx = Δy)
And for circular rod (which is in the center of the rectangle/square):
[tex] Aψ_{i,j} + Bψ_{i+1,j} + Cψ_{i-1,j} + Dψ_{i,j-1} + Dψ_{i,j+1} = 0[/tex]
where:
h = Δr
k = Δθ
[tex]A = -2(\frac{1}{h^2} + \frac{1}{k^2(a+ih)^2})[/tex]
[tex]B = \frac{1}{h^2} + \frac{1}{(a+ih)(2h)}[/tex]
[tex]C = \frac{1}{h^2} - \frac{1}{(a+ih)(2h)}[/tex]
[tex]D = \frac{1}{k^2(a+ih)^2}[/tex]
Are these equations correct? They will give me a set of linear equations that I can solve using Gauss-Seidel method, right? What units should I use to describe results in the specific points in the grid? Volts?
Beyond me at this point. Sorry.
  • · Replies 17 ·
